Dalton or Toby
Old May 1, 2007 | 06:58 PM
CHUPA_CABRA_2.0's Avatar
I need a new gas gauge
more details on this alarm Dan may have a buyer
facebook.com/modifiedstreetperformance
Old May 1, 2007 | 08:02 PM
Notladstyle's Avatar
King of Ricers
its a 2way paging Compustar alarm I installed it and would be uninstalling it.
its got excellent range and the only reason he is upgrading is because envy is driving him to get the remote start model I have in my car.
I believe it has
5 auxiliary outputs
external 2 step shock sensor
5 zone trigger
notladstyle.blogspot.com
Old May 1, 2007 | 08:09 PM
King of Ricers
Originally Posted by the727kid
Well it is armed, the doors lock and the blue light begans to flash. I looked at the antenna earlier everything seemed fine with it. And the wires going to from it to the brain.
take the battery out of the remote, cut all power to the car, put your key in and turn to ON, put the power back to the car, hold in the valet button till it resets, put the battery back in the remote.
You MIGHT have to reprogram the remote. See if that works...
Old May 2, 2007 | 06:02 AM
the727kid's Avatar
Connect the power when the ignition is in ON? That doesn't sound too safe.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old May 2, 2007 | 10:26 AM
King of Ricers
the alarm senses the ignition wires when it gets power. if you don't put the key to ON when you connect the battery it assumes its been stolen.
Theres nothing unsafe about turning the key to on with the power off.
Old May 2, 2007 | 11:11 AM
the727kid's Avatar
Ok I did that with no avail.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Old May 2, 2007 | 12:14 PM
  #17 (permalink)
King of Ricers
arent you running a voltage booster with your 83 batteries?
Old May 2, 2007 | 12:48 PM
  #18 (permalink)
the727kid's Avatar
No.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Old May 2, 2007 | 02:56 PM
  #19 (permalink)
King of Ricers
well if the doors lock but the remote doesnt say it then I would start checking the sensors - make sure they all set hte alarm off.
if they do then get a new brain.
