Elemental Design anyone?
I am thinking about getting some gear from ED like a 19ov.2 and a nine.1 amp for the back of my xB. I really would like to hear some ED products if anyone has any or can give some feedback i'd greatly appreciate it.
I never personally used them but I plan to soon. I have heard nothing but good about them.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Yeah same here everything i have seen has looked good so far. This guy told me he sees no prob hitting 140 + in my xB with one 18 ported and that 1200W amp. That excites me. My goal was to break 130 at some point.
What kind of 18? should be easy in an xB.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
search button works?
I have never seen eD talked about on here, I doubt there is much to search for.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
ED 19ov.2
Qts: .369
Qes: .37
Qms: 7.5
Fs: 26 Hz
Re: 3.5
Vas: 228 L
Mms: 307 g
Bl: 22.1 T*m
SPL: 90.5 dB
Sd: 1200 cm^2
Xmax: 22 mm
Voice Coil: 62.5 mm
Magnet Width: 8.200"
Cutout Diameter: 16.375"
Mounting Depth: 9.625"
Weight: 42 lb
Total Height: 10.600"
Displacement: .10 ft^3
Outside Diameter: 18.375"
Qts: .369
Qes: .37
Qms: 7.5
Fs: 26 Hz
Re: 3.5
Vas: 228 L
Mms: 307 g
Bl: 22.1 T*m
SPL: 90.5 dB
Sd: 1200 cm^2
Xmax: 22 mm
Voice Coil: 62.5 mm
Weight: 42 lb
If you're not hitting atleast 140 dbs with ANY 18 ported and 1200w, there's something majorly wrong. That should be a simple feat.
Now there's some logic!
