Where to get MDF cut?
Go with 3/4. You'll lose very little airspace. Anyways, if you do a whole box with just a jigsaw, well uh I hope you have a very accurate eye and steady hand. Tablesaws FTW.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Jigsaws are the ghetto way of building boxes. Get Home Depot to cut it and just make sure they do it right. Not that difficult.
Ghetto? for once u sound stupid John Jigsaws are the bread and butter of car audio.
once again, home depot will not make precision cuts. unless you like air leaks, get an inline or use a jigsaw.
lmao homedepots cuts are going to be less airtight then your jigsaw?? dude go to homer and have them cut it, double check your stuff before you go.. they WILL recut if you specifically tell them a size and they cut it wrong.
they throw it up on a wall cutter - even someone putting effort into it will be 2~3mm off and thats enough to make a gap in a panel.
And yes, if you have ANY skill with your hands a jigsaw cut will be as clean and accurate as the line you drew to follow. I'd say a powerful enough jigsaw will be at least as accurate as a circular saw.
.....like I said Table Saw FTW.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
I'd get ahold of a friend with a table saw, hole jig, and bring that jigsaw with. Any straight cuts I would never use a jigsaw on (you'll end up siliconing the hell out of that box and still not be airtight). Jigsaws are made primarily for complex cuts and will rarely produce a cut similar to what a table saw can.
Home depot fucked my cuts for my girlfriends box. Something was wrong with the blade and was cutting the mdf at an angle. I used a shitload of liquid nails to make it work but it was a pain in the ass.
wall cutters cannot cut mdf to more than a few mm of acuracy. Its not that the operator cant do it, its that the blade is so massive and theres no means for error correction.
I dont know why anyone would suggest it.
