Need Help with install
Alrighty then, well... I own a 1988 Mustang GT and I might be doing my own audio install on it. I have ordered Infinity Reference (2-ways) all around, and a Legacy 600x2 Watt Amp. I will be using a Rockford Fosgate RFX9210 Head Unit and running new speaker wire all around. The questions I have are as follows: First off, this head unit has no RCA's on it, but it has 2 areas for pin connectors. I've done some research and I assume that I have to get some sort of pin connector that has RCA's on it, but I can't find this *ANYWHERE*. Where could I find this part, if it exhists? My next question is, if I find that RCA plugin, do I still need to get a wiring harness? If so why? (To power the head unit? To power the Amp?).... Thanks in advance everyone! Sorry if I sound retarded, this is my first full install.
You will need your car's wiring harness in order to avoid cutting up the stock wiring. You will need another kit (8ga wire kit) to power the amplifier. You may also possibly need an antenna adapter to fit the stock radio to your aftermarket.
Shopping list:
One four channel line level converter
One 8ga wiring kit with RCA cables
One Wiring harness
One Antenna adapter (maybe, crutchfield can tell you)
Mounting kit (again, check crutchfield)
my and my freind hooked a kicker CVR 15 up in his satern wagon on a 750 watt amp.. we went and got a converter that said i belleave it was 60 watts and it worked fine...but befor we got the converter we had it hooked though the highlow input
sub stage. 4 american bass XD 15's
sub amps. 2 audiopipe APSM1500's
mid's. 16 american bass SQ 6.5's 8 pyle pro super tweets
mid's amps. 2 autotek ATX3000.2 and 1 autotek ATX950.4 on the tweets
Yeah I forgot about that, if the amp has a high.low built in you dont need to buy one separately. Just run speaker wire to the rear from the headunit to the amp and then from the amp back to the front from the output.
also, run your 4 speakers at 8 ohm, not 2ohm.
The sound will be much cleaner and you will have a little bit larger overhead as far as damaging the speakers at high volumes.
