dvd/ebrake bypass
Old Nov 19, 2006 | 08:40 AM
the727kid's Avatar
If just grounding works than that should be good! Unless it's a Pioneer head unit I would say you should be good.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Nov 19, 2006 | 08:54 AM
the727kid's Avatar
Ooo It ain't working at all.
Buy a toggle switch, connect the parking brake wire to one end and ground the other end. Problem solved.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Old Nov 19, 2006 | 09:45 AM
Notladstyle's Avatar
King of Ricers
you gotta do the togger switch or by a pulse sequencer off ebay that will do it automaticly when you turn ur dvd player on.
notladstyle.blogspot.com
Old Nov 19, 2006 | 10:19 AM
the727kid's Avatar
Pulse sequencer.....hmmm, info about that, never heard of it.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Old Nov 20, 2006 | 06:12 AM
King of Ricers
eBay Motors: Pac TR-7 TR7 Alpine Video Bypass IVA-D300 D900 D901 NEW (item 180050971199 end time Nov-20-06 16:33:04 PST)
^ That is a pulse sequencer, is just gives + or ground to a programmed lead for a programmed amount of time. The ones on ebay are programmed for ebay products but you can reset/reprogram them as you see fit.
