Yey fiberglass again
Old Nov 9, 2006 | 11:42 PM
Notladstyle's Avatar
King of Ricers
Default Yey fiberglass again
Soo, when the ricer in you says air bags arent cool, what do you do with that big ugly hole? build a pod!
I'm in un known territory here so many more prototypes are to come. which is cool because it takes 1/3 of a qt to make one.
We are still in the experimentation phase - suggestions welcome, flamers can visit my schlong for fire extinguishment. anyone got a good idea on what material/method to use to get the "flush" look with the dash while keeping it removable?
We are on pod #2 and I have the angle right but shaping & securing it to the dash and still being able to remove it is gonna need a a few more tries to get right.
notladstyle.blogspot.com
Old Nov 10, 2006 | 05:35 AM
TJElite's Avatar
I think I'd lay the monitor back a little, so its not so in your face. As for making it fit, you could either use an original air bag cover as a base, or make a new panel. I can give you some tips on how to make a new one, but its hard to explain in type.
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
Old Nov 10, 2006 | 06:25 AM
King of Ricers
we will have to check it out in person, its further back on hte dash than it seems, theres about 3" between it and the window.
The stock piece is basicly a piece of vynly and is very flimsy. And as you can see theres a curve at the bottom so im at a loss as to what to use that can flex like that.
Old Nov 10, 2006 | 06:43 AM
joebobclark's Avatar
Your Moms New Boyfriend
Use the vinyl cover as a mold. Cover with foil, layer on your fiberglass. It may not be perfect, but it will get you real close as far as shape needed.
Old Nov 10, 2006 | 08:40 AM
the727kid's Avatar
I would say lean it back more as well, is there anyway you can lower it to or is there something in the way?
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Nov 10, 2006 | 09:16 AM
King of Ricers
the vynlye cover isnt the correct shape - it was reshaped when the airbag deployed.
It matches up with the dash where it is - lowering it would look weird but we'll at hte meet what people think.
Old Nov 10, 2006 | 09:35 AM
King of Ricers
Can't lean it back more without it touching the windshield.
Can't lower it without taking the airbag out, something we really want done. Unfortunately they are attached with large Tamper Proof bolts, something thats hard as fuck to find the bit for.
Old Nov 10, 2006 | 12:30 PM
jriggs's Avatar
is better than you™
you can always just drill out the bolts
Old Nov 10, 2006 | 03:40 PM
King of Ricers
airbag brackets are quite difficult to drill out.
I'm hoping toby has the bolt or something applicable to remove it.
Old Nov 10, 2006 | 04:24 PM
P057's Avatar
isuck
they are "tamper proof" style bolts, shaped in a huge star and have a thick pin jutting out in the middle. was kinda lucky found a bit set at advanced auto that they arent even supposed to sell but the bits were a tad too small.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
