Tuning system ????'s
Old Oct 10, 2006 | 01:56 PM
hondachris1994's Avatar
hatchback1994
Default Tuning system ????'s
just wanted to know if the way Im tuning my system in is the rt way.....For the mids and highs I take and turn the gain down all the way on the amp and turn my radio to 35 (all the way up) and then I slowly turn the gain up until the speakers are at peak with no distorting...Is this the correct way to do it or should I not turn the radio all the way up and tune from a lower level say like 30(volume)...and the subs the same way??? Any help is very appreciated
Thanx
-Chris
Old Oct 10, 2006 | 06:33 PM
TBSpyder's Avatar
Sounds good and safe to me.
Old Oct 11, 2006 | 12:58 AM
hatchback1994
cool thanx
Old Oct 14, 2006 | 05:22 PM
the727kid's Avatar
That is one way. A more accurate way is to use a DMM and set them with that and test tones (1khz for mids)
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Oct 14, 2006 | 06:32 PM
sprjit22's Avatar
Rick James bitch
turn all your gains down real low. Start at the head unit & turn it up till it starts to have a little distortion & then turn it till it is a little below distortion & then go to the next device in line from their.
example: Head unit------ eq------ crossover-------amps
Always turn it all down & start at the head unit & work your way throught the system from their all the way to the amps...
Old Oct 16, 2006 | 05:16 AM
93ex's Avatar
Just Ledoux it!
If I turn my gains all the way down, and my HU up, I dont hear very much at all
Old Oct 16, 2006 | 08:52 AM
sprjit22's Avatar
Rick James bitch
All you are doing is listening for the head unit to start to distort & then you go throught the rest of the system & do the same. You dont have toi have the gains completely down but real low & listen closely
Old Oct 16, 2006 | 04:28 PM
the727kid's Avatar
Go buy a DMM for $20 and do it right.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Old Oct 16, 2006 | 06:40 PM
TBSpyder's Avatar
I wouldn't necessarily say that's the "right" way to do it...
Old Oct 16, 2006 | 09:25 PM
the727kid's Avatar
It is the most accurate way without using an o-scope.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
