matchin an amp?
i recently purchased two ten inch eclipse sw6103dvc....lookin into JL amps....was wondering whether to go with the 250/1 or the 500/1....they are rated at 200 RMS.....was wonderin if the 250/1 puts out 250 to both speakers or 125 to each...because my dad has the same subs with a 250/1 and it sounds great....but if i could get a little extra thump with the 500/1 without damaging the speaker that would be nice.....
The 250/1 puts out 250w rms total power...meaning 125 per sub. I'd go with the 500/1 if I were you though....those subs will be fine.
500/1 puts out 500 watts at max volume. How often do u turn your deck to the max volume and drive? How come no1 considers this?
Because max volume is not what the industry goes by. All products are rated along similar guidelines.
Now if your a dousche and you max the gains to .2 volts you will get 500w a lot sooner.
