mark 8 amp info needed
ok i got a 95 mark 8 with the JBL system and i want to pull the stuff radio out and put in my aftermarket deck is there a stock amp and would i need to rewiring the car or can i use the stock amp with the aftermarket deck and make it sound good i would like to make it look very clen anyhelp would be great.
2008 Acura TL DD
1998 Beater Ranger DD
1994 Ford Mustang Project
2008 Acura TL DD
I'm sorry I cant understand what you're saying.
dont waste time looking for an amp unless you have to. Take a 1.5v battery and tap the speaker leads. if its amped you will get nothing or one little click and then nothing. If its not amped you will get lots of crackling.
if you have an amp
Solder + RCA plugs + harness = use stock amp.
if you have an amp
If its the amped system, the Metra 70-5513 plug should be a plug and play amp bypass and take no more than 10 seconds to install once you get to the amp, which is usually in the trunk/under the rear deck. Spend the $20 at your local circuit city to save the headache and bypass the factory shit the easy way. Other than that in the trunk, should be a typical radio install in the dash.
daltons way works too, I do it on Bose sometimes, but if it were me Id buy the plug and play bypass.
Now there's some logic!
