speakers sound like crap????
Old Jun 6, 2006 | 11:44 AM
TIM TIM TIM's Avatar
could be worse
Default speakers sound like crap????
i just put my KS and SS componet speakers in the new car, for now there running off the head unit... when i pulled the ks speakers out of the old one they worked perfect, hook them in this one and they almost sound blown, they are distoreted as hell... so i figured who knows maybe there blown. so i took the SS ones directly out of the box (BRAND NEW) and they sound the same... there running off an eclipse head unit (cd300). could it be the deck? i thought it might be the factory wiring so i re ran my own wires and they still sound the same.. any ideas??
aim:because tim said
Old Jun 6, 2006 | 11:58 AM
djgizmo's Avatar
Sound Engineer for Hire
Test the speakers on another deck (or even a home receiver) for a quick test. That will eliminate if the speakers are the problem. When was the last time you hooked up speakers directly to your deck?
"Your Music, Your Tunes"
Old Jun 6, 2006 | 12:06 PM
could be worse
2`days ago and before that a week
Old Jun 6, 2006 | 02:08 PM
Notladstyle's Avatar
King of Ricers
would try another deck to eliminate the amp as a source...
also examine your crossover situation. polarized crossovers will go bad much faster than non-polorized.
notladstyle.blogspot.com
Old Jun 6, 2006 | 05:18 PM
could be worse
dont know the differance between polarized and non polarized but there the ones that came with the speakers and there for sure wired right, i doublt checked.
Old Jun 6, 2006 | 05:57 PM
King of Ricers
i would check another vehicle, you may have grounded the speaker leads out and damage the headunits amp.
Old Jun 7, 2006 | 02:30 AM
could be worse
how would the speaker leads be grounded? like how can i check?
Old Jun 7, 2006 | 03:17 AM
TJElite's Avatar
If by this you mean polaraized caps, they go bad real fast, and they donj't work, because they are designed for DC...sound is AC. I don't think any manufacturer would use polarized caps for crossovers.
I'd do what others have suggested, and try another source. I'm betting its the deck.
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
Old Jun 7, 2006 | 12:39 PM
King of Ricers
Toby
I have discovered polarized capacitors in cheap, low power coaxial speakers inline with the tweeter.
Old Jun 7, 2006 | 01:55 PM
TJElite's Avatar
Scary, but not surprising. I guess if you can save .00002 per coax pair, why not.
If they had to do it somewhere, I guess the tweeter is the best, at least from an electrical stanpoint. Tweeters don't see much power, and the high frequencies get DC like.
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
