Amplifier questions
Not only that but bass is generally an all around sound. meaning that its a little tougher to distinguish where it is coming from when you listen to music (at the appropriate levels) so it wouldnt make too much of a difference.
If you arent convinced by our information that we're giving you, you can basically get the same general information from a reputable source --
http://www.crutchfieldadvisor.com/le...rs_faq.html#19
It says what we're telling you.
get the monoblock
get the monoblock
Originally Posted by Largo
Well, see, I was just listening to some music and messing with the left and right channels, and one channel would have the highs and one would have the low stuff, so that is why I wanted a stereo sub, because sometimes it would be the left channel sometimes the right.
I'd suspect that what you are hearing has more to do with speaker placement. Take typical door speaker installations, for example. From the drivers seat, the drivers door speaker is nearly 90 degrees off axis. The higher the frequency, the more directional the sound, and the less it will be heard off axis. The passenger side, however, is almost perfectly on axis, so the higher frequencies will seem much louder. At the same time, the passenger speaker is farther away, which affects lower frequencies more, so they will seem softer.
There's actually quite a bit more to this...maybe I just found my next Tech topic...
Toby
I see, well, mono block it is then. I just didn't know what a mono block amp did I guess. Thanks guys
Originally Posted by ChristiMarie
Patrick
All around perfect man and a sexy beast. Known to cause even the most loyal of girls to turn on their boyfriends. Some consider to be on the status of not only a god, but THE God.
"Damn, my girl got snatched..."
"Kick his ass dude!"
"Nah man... it was Patrick bro"
"Awww shit... leave it alone, that fucker will kill you"
"I didn't know Jesus went to this school"
"Nah dude... that guy right there, that's Patrick. But they are easily confused"
