What wire do you use?
Old Apr 24, 2006 | 06:47 AM
Eclipse99RS's Avatar
Leaving March 6th
stinger everything
JL Audio all the way!!!
^^R.I.P. 08/04/04-11/28/05^^
I hate illegals in 97 Chevy Blazers!!!
Old Apr 24, 2006 | 06:54 AM
TBSpyder's Avatar
Originally Posted by suprapimpa
I'm getting an idmax and running it off a zapco 1100.1 reference series amp, what wiring do you think I should use? I read somewhere that if the wiring is too big it will draw away power just like if the wire is too small, so I really want to get it just right since I'm spending all this money on a sub and amp.
Thicker wiring has no negative effects. It's like water running through a pipe.
Old Apr 24, 2006 | 08:47 AM
Notladstyle's Avatar
King of Ricers
AC current is affected by wire length and volume. But the energy loss would be neglegable when dealing with such a short distance at such low frequencies in a vehicle. The reaosn is the wire itself has a capacitance which must be caneled before current can flow in the opposite direction. This most affects high frequencyies and very voltage sensitive applications. If you want to be sure, just dont use something ridiculous like 10ga wiring.
In home electrical systems, an extra 50ft of wiring can reduce home voltages by 5 volts depending on the type and quality of termination.
notladstyle.blogspot.com
Old Apr 24, 2006 | 08:50 AM
King of Ricers
water doesnt alternate direction several hundred times a second. It does make a difference.
Old Apr 24, 2006 | 07:55 PM
TBSpyder's Avatar
I'm referring to power cables.
Old Apr 26, 2006 | 11:25 AM
passfan's Avatar
Would you be so kind as to provide your source for these new theories so that I might take a peek?
Old Apr 26, 2006 | 12:47 PM
  #17 (permalink)
King of Ricers
new theories? AC current isnt a new concept. if you dont understand the principle behind how AC current works google it. My reference is one of my college textbooks: Electrical Theory by Mike Holt. You can find it by taking a peek into low level EE classes at USF.
Old Apr 26, 2006 | 12:52 PM
  #18 (permalink)
passfan's Avatar
Current doesn't change directions in the wire either. AC Current alternates around a zero pole point in the generator hence the name alternating, and it's 60 cycles not several hundred.
Old Apr 26, 2006 | 12:54 PM
  #19 (permalink)
King of Ricers
Umm guess how many times AC current changes direction in one cycle? Twice!
Old Apr 26, 2006 | 01:01 PM
  #20 (permalink)
passfan's Avatar
And two times sixty is several hundred? You've got a long way to go and a lot to learn and your quoting an entry level book used to introduce high schoolers into trade school. Good luck
