Blown or not blown, this is the question
Old Mar 25, 2006 | 04:15 PM
Bumpin Expo's Avatar
Reppin' the 813
Default Blown or not blown, this is the question
This is my SI d2 15" subwoofer that is dual 2 ohm voice coil. About 2 weeks after I put my sub from ported to sealed, this started. It sounds like I have an air leak and when I checked I dont. It only makes the sound when turned up real loud, but when turned up a bit the bass sounds fine. The following ohm readings is what I found out. What do you guys think
(dual voice coil, one reading for each coil)
Old Mar 25, 2006 | 04:36 PM
TIM TIM TIM's Avatar
could be worse
wierd... i thought when its blown it just wont read any ohms ?
aim:because tim said
Old Mar 25, 2006 | 05:37 PM
Notladstyle's Avatar
King of Ricers
The voice coil has partially melted and will soon completely fail. Theres pretty much nothing you can do except get it refurbished.
** EDIT **
I just took a closer look at the picture and your ohmsmeter has the low battery light on. That could return erroneous readings of the impedance and void what I said above.
notladstyle.blogspot.com
Old Mar 25, 2006 | 07:07 PM
TBSpyder's Avatar
Yeah, it'll rear higher ohm loads if the voice coils or tinsel leads are damaged. I'd get some new batteries in your meter before anything else though. You coming out to the Audio Meet on April 8th?
Old Mar 25, 2006 | 07:21 PM
Reppin' the 813
good call, ill retake some measurements tomarrow... Good eye !
