Amp past repair??
well me and my friend pull up ionto my driveway and his amp turns off due to a stuborn ground that we didnt take the time to get a good firm connection. so i say fuck it man lets do it right. i get a great connection and go to test it it doesnt work so we check the infile fuse block near the battery and its blown we replace it and the fuse in the amp itself and we go to test it this time and i hear "crack, pop".... and then "sizzlleee....." and smoke. it came right in the amp where you hook up the power wire. so im thinking maybe it can be repaired.....
(hopefully) can anybody fix it?? or should i take it to Auto Audio and see what they can do?
and he replaced the fuses before and im not sure what they where before he replaced them because i wasnt there but he said he put in a lower amperage fuse which i really didnt like its a 1000 watt amp is there anyway that you guys can tell me what amperage fuses should be used??
Thanks, Joe
(hopefully) can anybody fix it?? or should i take it to Auto Audio and see what they can do?and he replaced the fuses before and im not sure what they where before he replaced them because i wasnt there but he said he put in a lower amperage fuse which i really didnt like its a 1000 watt amp is there anyway that you guys can tell me what amperage fuses should be used??
Thanks, Joe
Thanks, Joe
Thanks, Joe
well what if it is a JL 1000 wuold you be able to rebuild it or would it be Auto Audio? i say this because im not exactly sure which amp it is.....
Thanks
Thanks
not quite time to start rebuilding amps.. almost.. but not quite. If its like one component then I could do it but usually smoking amp means more than a few things burnt out, try Auto Audio but for the price you could buy a new one.
alright man ill check with them and see what they want to rebuild it. he only bought it for 100 bucks and that was installed by a friend i dunno i hope that they arent to expensive
where are u getting ur EE degree from and what is it exactly lol i'm guessing its about electronics lol.....
I'm going for electrical engineering @ USF. I might change my focus to computers though, writing viruses that spam people to buy penis enlargement products seems to be very lucrative.
1000 watts/4ohms = 250amps peak draw how many slots are there?
