beginner
Old Nov 4, 2005 | 08:40 AM
GearGrinder's Avatar
ridin high
Default beginner
well i have never hooked up a stereo before..
I aquired a system from a friend who owed me money he gave me his system instead now he lives out of state...
anywho...
i have 2 12s TREO enginerring subs in a box/ built on box amp and a digital volt meter built into the box as well... the amp is suppost to push 500 watts and 1200 rms
the subs are suppost to be 500 or so.
anyway i am hooking it up tomorrow and i need to know what wiring to get and everything.
what all should i buy to hook this up right?
thanks for the help
Own an APBT? visit... www.mypitbullpro.com
Old Nov 4, 2005 | 01:56 PM
Will_Evo's Avatar
Specialist
Default Wires
You need a power wire(A small gauge like a 8 or 6) to run from the power slot on the amp to the battery.
You need about the same size wire to run from the ground in the amp to a good ground bolt in the back ie. a strut mount.
A smaller gauge prol 12 as a remot wire to tell the amp when to turn on, run it to a fuse that only workls when the car was on.
And RCA cables hope that helps
Old Nov 4, 2005 | 02:32 PM
integralsgreen's Avatar
go to walmart and buy the sosche amp wireing kit. its cheap its got everything you need and has decient instructions and diagrams.
