My big hifonics amp keeps melting its fuses in the power wire....
Old Sep 30, 2005 | 07:54 AM
GradeA_TireFryer's Avatar
All American, rice eater!
You Should Add A Ground Wire From Battery - To Chassis Ground Same Size As The Power Wire + Run From Battery To Amp.
And It Would Not Hurt To Add A Ground Wire From Engine (attach Close To Alternator) To Chassis Ground
Old Oct 3, 2005 | 03:30 PM
integralsgreen's Avatar
upgrade wires+fuses if ur still blowin fuses ur amp may have a bad resistor. hifonics amps draw alot of power so id say u need a bigger fuse
