Help please..Locked screen?
Old Sep 9, 2005 | 10:12 AM
Notladstyle's Avatar
King of Ricers
Originally Posted by Skittle
DEAL!...
Which wire is the E-Brake wire?..Is it in the main harness or separate?
either integralsgreen was right about simple grounding the green wire off the back of the screen, OR if its a new screen you will need a bypass box. ebay has some cheap ones to get the job done.
so uhh, when do i get some TR skank lovin?
notladstyle.blogspot.com
Old Sep 9, 2005 | 01:11 PM
kender's Avatar
gadget man
grab your owners manual and see what it has listed in the install section. if it is just the e-brake then it will show 1 wire, it may be in the main harness for the unit or it may be in a small sub harness. the wire for your car will be near the e-brake. If you can post up the right model number ( since you said you weren't sure if it was right) I may be able to tell you which way it is. if you do need a bypass I highly recommend the pac tr-7, the ebay listing may not mention all available models. I have an alpine iva-d310 and the guy on ebay said it wouldn't work ( but he had a more expensive one that would) I went to the pac website and contacted them, they said it would, and it did. I did the entire hookup myself and it works flawlessly.
U.S.S.A Crew Member #001
Old Sep 9, 2005 | 02:38 PM
Skittle's Avatar
You Can't Moderate Me.
I dont have a owner manual,i picked it up from my friend,he replaced it with a motorized screen...that model number is the right one,i googled it ...Still couldnt find a wiring diagram or anything though ...All help is appreciated thanks again!
R.I.P Pablo "Fathead" Garcia & Kevin "Slo_Si" Gonzalez Forever in our hearts.
Old Sep 9, 2005 | 05:12 PM
TBSpyder's Avatar
Whoever hooked it up didn't do it right. For $50 I'll make it so you can watch it while driving.
Old Sep 11, 2005 | 02:50 PM
Skittle's Avatar
The cd player itself is hooked up right,everything works 100%..besides,the :aux: screen,and it displays "this screen is blocked for your safety"...I think it needs the actual grounding wire.Not sure...Do you still work at Sound Advice?
Old Sep 11, 2005 | 03:08 PM
Skittle's Avatar
Btw-What site would i find the wire on?..Ive searched for 45 min and still cant find it!
Old Sep 11, 2005 | 03:30 PM
  #17 (permalink)
kender's Avatar
gadget man
http://esupport.sony.com/perl/model-...?mdl=CDXM9905X
looks like the light green wire just needs to tap onto the e-brake, which means ground. just connect to ground and you should be fine.
Old Sep 11, 2005 | 03:59 PM
  #18 (permalink)
Skittle's Avatar
I found a "cord assembly" on that site,is that what i will need to order?
Old Sep 11, 2005 | 04:15 PM
  #19 (permalink)
kender's Avatar
gadget man
on the main wiring harness that has the power, ground, speaker wires, power antenna wire. etc. there should be a light green wire. the light green wire should be connected to the e-brake or ground if you want to bypass it. when you go to the link I posted click on "Installation/Connection Instructions" under where it says manuals. it'll open a pdf that you can save or print for a hard copy.
The instructions don't say what the cord assembly is, so I am only guessing that it may be the main harness, your audio/video inputs are rca connections, like $4 at walmart. the screen locked is from it not getting the right signal from the e-brake wire( light green).
Old Sep 14, 2005 | 05:33 AM
  #20 (permalink)
93ex's Avatar
Just Ledoux it!
You shouldnt have to buy anything else... just take thelight green wire and ground it. it shoudl be on the harness already
