Fiberglass fumes mmmmmm
King of Ricers
on
ooh the fumes oooohh
This is what happends when you are too lazy to go buy mat.... and you are high off of fumes and put the sub in backwards.
other than that, turned out alright - welcome to the world with very little fiberglass, welcome to fleece glass box... yeah im serious I ran out of mat at like 9 oclock so i used fleece. yes it worked. no im not an idiot errr well nvm it worked.
King of Ricers
on
Originally Posted by 93ex
the lack of mounting rings/baffles is really looking good there
As far as sound, its lightning audio, so you cant expect too much. But the phasing is PERFECT, and having the sub facing forward from the rear sounds much betta than facing rear from front.
King of Ricers
on
Originally Posted by integralsgreen
i wanna see it when its finished (carpet, clean up the wires, mount the amps, ect.)
For the amps im going with classic rear mount - of course when i finish it will be carpeted and all the wires will be cleaned up and the cover will be on the amps(had to do a lil optimization
ahh whered the speaker go lol. id just use some bondo to clean up that box n have straight lines. also use some grey carpet and streach it a little more. mite just be the box but it looks like i see lines in the carpet where 2 ends meet in the corner. dosent look too bad, i wouldent through it out. plus it would save you mony just to bondo this one up.
King of Ricers
on
King of Ricers
on
shoulda used mdf rings, woulda ben more sturday
