Question with amp & power cable
I have a 400w Lanzar vibe amp, hooked straight up to two 4-ohm RF HF2 10" subs in a sealed enclosure.
I used to run this same amp with 2 8-ohm 12" Kicker comps, bridged mono.
I would like to run the RF subs bridged mono. (2-ohm load)
Some people have told me this amp should be able to do a 2-ohm load, however when I try it, the amp goes to protect as soon as some bass hits.
My question is this: Could the amp going to protect possibly be caused by a power cable being too small a gauge? I think the cable I have run is a 10-gauge, which seems to power the 2 subs fine at 4-ohm, I just want to get a bit more power to them.
Thanks for any insight you can give me.
Offroading Spots near Tampa
Green markers = Pay spots
Blue markers = safe free spots
Red markers = not so safe free spots (possible trespass issues)
2 channel! thats why i want to bridge it mono.
in trying to research it, it doesnt appear to be able to handle a 2-ohm mono load, but it says it can put out 175 x 2 @ 2-ohm ?
Couldnt find any specs for HF2 subs? Are they HX2 or HE2?
Either way, they should be dual voice coil (DVC) 4-ohm. You can run the amp bridged to get full power from it, you will just have to re-wire the subs, to produce a single 4-ohm load.
Hope that helps....
Hope that helps....
Your other option is to wire each speaker to a 2-ohm load and connect to each channel of the amp.
I dont know which would be better in your case, as I have no idea the specs on a Lanzar amp. Try each one, see which sounds better to you.
BE CAREFUL!!! Dont let the amp overheat, especially in 2-ohm stereo.
Hope that helps....
Hope that helps....
Sorry I meant HE2 and I dont believe they are DVC...
