optima batteries
Originally Posted by NoTLaDStyle
Dude for any decent system those half size batteries will NOT do. you will either have a hard time starting or constant draining. You really should relocate it or spend the 150 at advance and get the half size optima
Originally Posted by Taint Paint
a 2000 dollar system in a 500 dollar car is ridiculous enough, i don't need to go rewiring the whole damn electrical system around it.
JFWY
it's a regular size battery, actually it's bigger than the optima. the optima would have been sliding around in the battery tray. a friend of mine had a similar sized battery in his contour and it slid around and would randomly disconnect from the cables. so no dice on a non-oem sized battery. i'm not going to go to all the trouble of relocating the battery because i just plain don't care that much. a 2000 dollar system in a 500 dollar car is ridiculous enough, i don't need to go rewiring the whole damn electrical system around it.
As for the sliding around, there should be an OEM bracket that holds the battery, if the car didnt have it, the battery wasnt oem size anyways. people commonly upgrade civic batteries to 78y when they need 75 and throw out the bracket that clips to the battery, then you cant go back to 75 without it sliding...
