capacitor wiring
capacitor wiring
My friend needs me to hook up his 2 poineer 12's his amp and a cap, and the only thing im not sure of how to do the the cap? can someone find a easy diagram to read or draw one? thanks for the help..
Originally Posted by TBSpyder
If the cap is new, you know you need to charge it right?
usually it comes with a small light or the cheaper ones just have a little wire thing you use.. basically with wiring it, just go from battery to cap to amp with power, and negative you can run to the same place as the negative of the amp, or connect them, whichever is easier.
