Anyone in here have technical experience with Amps?
Old Mar 2, 2005 | 03:41 PM
SSpiro's Avatar
Errare Humanum Est
Default Anyone in here have technical experience with Amps?
My Zapco amp keeps cutting out whenever I turn my system up.. Can only keep it at 1/4 volume before it starts cutting out..
To clarify: It doesn't skip; I can still hear audio from mids/highs, but the bass cuts out. Further investigation shows that the amp actually turns off at higher levels (power LED goes out, fan turns off) but turns right back on. Sometimes amp cuts out after going over speed bumps, rough turns, etc. I have investigated all connections and everything is secure and complete. Remote, ground, power is all secure on both ends. Even took off the power connection, restripped, and reconnected for some fresh copper strands..
Obviously this is quite annoying. Any thoughts? I PRAY my amp isn't going dead.. Anywhere else I should check?
Old Mar 2, 2005 | 04:25 PM
93ex's Avatar
Just Ledoux it!
head unit? May sound odd, but if the pre-out voltage drops, or one of the connectors isnt making a solid connection behind the h/u.
or turnt he gain down? or else the amp is en route to out.
Old Mar 3, 2005 | 04:18 PM
SSpiro's Avatar
Errare Humanum Est
Summabitch..
OK. I will take the deck out this weekend and double-check these connections. The deck itself is only 6-9 months old..
Old Mar 3, 2005 | 05:54 PM
TBSpyder's Avatar
It's those shitty Zapco amps.
I agree though, check your remote turn on and your deck. Swap in a different deck if you can to test it.
Old Mar 4, 2005 | 02:41 PM
SSpiro's Avatar
Errare Humanum Est
Well, looks like it may have been the remote. Took the deck out and upon first inspection everything looked OK. As I was about to let out a "what the fu.." the remote line from the amp fell out of the crimp. Turns out it was real lose. Restripped and recrimped, and so far so good. I haven't driven anywhere, but appears to be better already.
Thanks guys.
Billy
Subaru Tech
Feb 20, 2013 02:33 AM
Whaazup17
Nov 15, 2003 06:54 PM
