Elemental designs install
Originally posted by Turbo GSR Civic 95
best thing to use IMO is 100% silicone it stays soft forever and won't crack over time like liquid nails does
Originally posted by racingtheburg
box= quazimoto bitch wouldnt seal so I got crazy with liquid nails and screws lol
Liqouid nails does infact break down over time. I've seen countless projects come back over a years time because of it. I personally use wood glue, brad nails, and silicone caulk on enclosures.
the wood glue will hold the wood much better then those screws ever will be. the reason to use the nails or staples is just to hold it together while the glue dries.. you did give your silicone enough time to dry right? if you play anything within like a day of sealing it, its going to blow through
