home system
Old Dec 3, 2004 | 05:15 PM
eli's Avatar
eli
Default home system
we finally cleaned out our garage and were turning it into a game room. i thought itd be cool to put a radio in there, wiht some subs. only thing i dont want it to run off my regular home stereo so i just wanna pick up a cheap amp and sub and throw it in there. what all would i need. like u know at the audio place they got everything setup so they can test ur stuff out well i think i got the idea of what they have setup but not quite sure.
Cd player, itd need rcas to plug into the amp .
Remote- i could run a remote from the amp and jump it to the power coming from the battery
Car battery
ground- coming from car battery to amp
power- from car battery to amp.
sub
is that all itd need? i was just wondering about the cd player, do i need to connect any of the wires from the harness or are those just when u actually plug it into the car.
Old Dec 3, 2004 | 06:45 PM
TBSpyder's Avatar
You need a big ac/dc converter that plugs into the wall if you want to run a car amp. If you hook the amp up to a battery, it's just going to die. The car audio sub would work off a home audio amp. Either way, kinda a dumb idea if you ask me....home audio equipment is much more efficient than car audio, therefore you'd probably get better results with less money if you just stuck to home equipment.
Old Dec 3, 2004 | 06:48 PM
MDIFYTD's Avatar
Uber lurker
Why not just buy a cheap home stereo? If you're after decent bass you could always buy a plate amp from www.partsexpress.com and mount it to the sub box you make at least that will run on 110.
As for the CD player there should be a diagram on the top of it. There will be some stuff you obviously don't need like power antenna or illumination.
Also you're going to have to get something to convert 110 to 12.
Ill say i go by His and Al's thoery of "Your getting sprayed" Doesnt matter what it is. Grandma in the 1982 LTD is gettin the bottle.
MDIFYTD's Avatar
Uber lurker
Beat me to it John
Old Dec 3, 2004 | 07:12 PM
eli's Avatar
eli
cool thanks. couldnt i just use a car battery and keep recharging it.?
Old Dec 3, 2004 | 07:13 PM
TBSpyder's Avatar
Originally posted by MDIFYTD
Beat me to it John
What can I say...I'm good.
Old Dec 3, 2004 | 07:15 PM
TBSpyder's Avatar
You'd have to recharge probably every 30-60 minutes. Kinda a PITA if you ask me.
Old Dec 4, 2004 | 05:38 AM
93ex's Avatar
Just Ledoux it!
keep a trickle charger on it full time!!! of course its a constant draw etc real pita ANYways, so its just best to do a cheap home setup
Old Dec 4, 2004 | 07:19 PM
eli's Avatar
eli
why would i need to keep recharging it so much? its not gonna be on alot.
Old Dec 4, 2004 | 08:24 PM
93ex's Avatar
Just Ledoux it!
the battery will most likley have SOME draw on it 24/7.
