Car audio
Old Nov 27, 2004 | 11:38 AM
RoXyChiCk821's Avatar
New Member
Default Car audio
I had two tens and a 400 watt amp in my car
One day my car wouldnt start... to make a long story short one of my battery cables had melted, the one that the power was attached and it broke the connection
Now.. could my system be to blame for this and if so what size wire should I get?
_*-CaTiE-*_
Old Nov 27, 2004 | 01:28 PM
GsEclipse02's Avatar
what size fuse do you have for your wireing kit if its to big it might have cause this ... not sure tho ...
Old Nov 27, 2004 | 01:45 PM
gabe's Avatar
clever individual
there is a car audio tech forum.
-gabe
Old Nov 27, 2004 | 03:22 PM
93ex's Avatar
Just Ledoux it!
was there a fuse in general?
Old Nov 27, 2004 | 10:43 PM
TBSpyder's Avatar
Did it melt because it was against something hot in the engine bay or what?
Old Nov 28, 2004 | 09:39 AM
Bumpin Expo's Avatar
Reppin' the 813
yup
Old Nov 28, 2004 | 11:04 AM
TBSpyder's Avatar
The only way your system could cause your car not to start (assuming it wasn't ghetto rigged in some odd way, ie through a fuse box or no fuse) is if your amp is pulling more current than your factory alternator/battery wiring can handle. And I seriously doubt this would happen with a 400w amp unless Ford uses 16 gauge power wire. And usually, if a wire melts because of excess current, a large portion of the wire is damaged...rather than just a small section as if it were to come in contact with something hot in the engine bay. If it is because of excess current, you better be lucky your entire car didn't catch fire.
Old Nov 28, 2004 | 04:45 PM
New Member
so the ground couldve caused it to do that? because there wasnt anything getting too hot in the engine itself
_*-CaTiE-*_
Old Nov 28, 2004 | 06:18 PM
TBSpyder's Avatar
Which wire melted? The power wire for your amp? Did you have a fuse on it?
