HU install
Old Oct 25, 2004 | 07:31 AM
Broadway's Avatar
2JZ-GE Powered
Default HU install
I am trying to install my HU in my car, but there are no availible wiring harnesses for my 94 GS300. I cant seem to figure out what wires to cut to hook up to the HU harness, and Ive heard that becuase I have a factory amp, i need to either replace or bypass it
if anyone can help out, or wouldnt mind spending some time with my nub ass I would really apprieciate it
Old Oct 25, 2004 | 07:46 PM
TBSpyder's Avatar
Yeah, you'll need to bypass the amp. Pick up the outputs from the amp (the wires between the amp and speakers) and run them to the aftermarket deck. Figure out the constant, ignition, and ground wires behind your factory deck and you're set.
Old Oct 25, 2004 | 07:57 PM
adero's Avatar
Uber 1337
check best buy for a wiring harness.
Old Oct 25, 2004 | 09:00 PM
PurpleEK's Avatar
amp is located behind the right side of the glove box and i think you can use a newer passport/rodeo harness and just re-pin it or you can just tag the wires there
wahoo i love my new car
Old Oct 30, 2004 | 07:36 AM
Broadway's Avatar
2JZ-GE Powered
my amp was actuallly located in the trunk...
I found a wiring diagram for my car and come to find out, my HU is a little fucked so I gotta buy another one, if anyone has one for sell then PM me
Old Oct 30, 2004 | 07:49 AM
Bumpin Expo's Avatar
Reppin' the 813
www.installdr.com
all ur wiring diagram needs
