static static static!!!
Guest
Posts: n/a
just recently while playing my radio i get static on every radio channel. when i play cd's everything is fine so it has something to do with reception. the funny thing is when i get in the car in the morning after it has sat over night, i will get perfect reception. then after about 10 minutes of driving the static slowly comes in and takes over. there will be breif moments when it will come back in. im using my oew power antenna on my integra. it goes up and down perfectly. no bends or any damage to the antenna. checked the back of the headunit and everything seems fine. anyone have any ideas? thanks for any help
I would go to walmart, buy a cheap antenna/cable, hook it up to the antenna in on your radio, and just put hold it up, test to see if that cures it. If it does, its your antenna, if it doesnt, its your radio
i have the same problum in my integra except it hapens when i have my subs on. if i unplug the power to my amp i get perfect reception but with my amp on its all fuzzy. let me know what u found the problum with yours was or anyone else let me know what u think the problum mite be
