Need good AMP
I need a good AMP to power two 600 RMS 4ohm subs
If I ran both of them off one bridged channel, would that be a 1ohm load? Im no expert when it comes to car audio so bare with me
Should be 2ohms. Are they 4ohm single voice coil? Go with a mono block class D amp. They're usually stable down to 1 or 2 ohms mono and run more efficently then a 2 channel class a/b. I personally like JBL as a budget choice, I know Curtis has had good luck with Hifonics. Ofcourse there's other brands that are as good and better but you'll be paying atleast 2 or 3x's as much.
they are 10' power acoustic, not all that great (for 20 bucks for both i cant complain a bit, considering they cost like 120 each at BB) I just needed something over my stock system and to get me started
will do
i figured id go with the same brand of amp
http://www.cardomain.com/item/POWA1800DB
1100W @ 2 ohm and the reveiws i have read on this amp are all good, and its right in my price range, so this good enuff?
