quick question (wheel well)
Old Aug 23, 2004 | 12:39 PM
Akkord29's Avatar
Default quick question (wheel well)
Say you are putting a sub in the wheel well, is the sub mounted like this?
Box on the bottom, then the wall (for flush mount), then the sub on top of both, then screw down the subs.
01 Lincoln LS
01 Nissan Maxima AE
94 Acura Legend
Old Aug 23, 2004 | 01:30 PM
MDIFYTD's Avatar
Uber lurker
You can do it a couple different ways...
Top mount- the sub screwed into the baffle from the top which will leave the sub sticking up out of the enclosure ~3/8".
Bottom mount- The sub screwed into the baffle from the bottom which will sink your sub into the eclosure 3/4"(depending on the thickness of MDF you use)
I would top mount the the sub but make an additional baffle with a cutout of the outside diameter of the sub. Use wood that is as thick as your sub is tall when it sits in the enclosure. This way it a flush look.
Ill say i go by His and Al's thoery of "Your getting sprayed" Doesnt matter what it is. Grandma in the 1982 LTD is gettin the bottle.
Old Aug 23, 2004 | 02:03 PM
Akkord29's Avatar
thanks alot.....now i just got learn the basics of building a box, ive seen some threads about this.
01 Lincoln LS
01 Nissan Maxima AE
94 Acura Legend
Old Aug 23, 2004 | 02:58 PM
Lizzle's Avatar
TR Bike Tech Post Whore
And spends weeks doing fiberglass work?
So you're Chekhov, huh? Well, this here's McCoy. Find a Spock, we got us an away team.
Old Aug 23, 2004 | 03:16 PM
MDIFYTD's Avatar
Uber lurker
Yep add it to my list of incompleted projects
Old Aug 24, 2004 | 04:32 AM
93ex's Avatar
Just Ledoux it!
projects are best uncompleted
re: my kick panels
re: my diy components
Old Aug 25, 2004 | 07:09 AM
Akkord29's Avatar
does home depot sell the carpet to cover the board. And where do they sell the non hardening rope caulk to mount the subs in the box, because i cant seem to find that anywhere.
01 Lincoln LS
01 Nissan Maxima AE
94 Acura Legend
Old Aug 25, 2004 | 10:45 AM
93ex's Avatar
Just Ledoux it!
no HD wont sell that carpet.. discount has rolls of grey carpet or balck but its not that nice
gulf fabrics i belive has what you want or www.selectproducts.com
now non hardening caulk to mount the subs? dont use any liquid to mount the subs, that will just be a mess. if you need some sort of sealant, use weather stripping. call some audio shops, most of the time they have some of the gasketing that is left over from other subs.
imho ive never needed any gasketing for my stuff
