help!!
Old Jul 25, 2004 | 06:48 PM
crazyeclipse66's Avatar
Default help!!
Here are the specs on my sub's I have 2 of them.
Recommended RMS Power: 200W
Peak Power Handling: 400W
What size amp should i buy to get the most out of the subs. Should i get a 400watt amp or an 800watt amp? Please help me Thank you!!
Old Jul 25, 2004 | 07:57 PM
kpr10is's Avatar
Maximaniac
Well you dont need two threads...but get an amp that is 200 watts RMS, which might be around 400 peak depending on the amp. Look at RMS though, its more important (see other thread).
Old Jul 25, 2004 | 08:00 PM
kpr10is's Avatar
Maximaniac
well according to your other thread, you have two of the subs, so get a 400 watt RMS amp if its a 2 channel, or around a 600 watt RMS amp if its a mono amp.
i really dont feel like explaining parallel or series wiring, or ohm loads, but theres much more to buying an amp than watts. do a google search, or i might come back and type later if im bored
Old Jul 25, 2004 | 08:32 PM
TIM TIM TIM's Avatar
could be worse
wow..get a 2 ohm stable amp... if the subs are DVC (dual voice coil) get 2 channel or mono... if you have SVC (single voice coil) then get a mono amp
aim:because tim said
Old Jul 26, 2004 | 05:05 AM
TBSpyder's Avatar
Stick with a mono class D either way. The JBL 600.1 I recommended in the other thread would work well with your subs as long as you keep the gains all the way down. And if you're really tight on cash, the JBL 300.1 wouldn't be a bad choice (plus you wouldn't have to worry as much about turning the gains up and cranking the volume).
Old Jul 26, 2004 | 05:55 AM
Default ok
Thank you i have one more question, my subs are 4OHM. What does that mean, and when lookin at amps when is says the watts at 4ohm's is that the watts they will be pushing my subs at?
Old Jul 26, 2004 | 06:22 AM
250W x1 @ 4ohms
500W x1 @ 2ohms
750W x1 @ 1ohms
RMS 250-50WATTS
If my subs are 4ohms how many watts are gonna push it?
Old Jul 26, 2004 | 07:55 AM
GsEclipse02's Avatar
Originally posted by crazyeclipse66
250W x1 @ 4ohms
500W x1 @ 2ohms
750W x1 @ 1ohms
RMS 250-50WATTS
wtf is that for an amp or a sub ?
Old Jul 26, 2004 | 07:58 AM
thats for an amp, my sub's are 4ohm i was wondering how many watts from that amp would push my sub's
Old Jul 26, 2004 | 09:44 AM
are your subs DVC or SVC if there DVC i would just run them at 1 ohm turn the gains down a lil bit to be safe but what brand of subs /amp do u have
