Price..
Old Jul 6, 2004 | 09:57 PM
RkSport's Avatar
Default Price..
I was wondering how much it would cost to hook up a head unit 2 subs and an amp.. need the wires..
Old Jul 6, 2004 | 10:08 PM
TIM TIM TIM's Avatar
could be worse
wires off ebay for like 25... depends where u get it installed... a car audio shop will cost you an arm and a leg but just get someone off here to do it, i doubt you would need to pay more then liek 30 to get it all installed.. considering you already have a box for it all
aim:because tim said
Old Jul 7, 2004 | 11:17 AM
GsEclipse02's Avatar
rich ur broke u dont have money for this lol
Old Jul 7, 2004 | 12:38 PM
RkSport's Avatar
ha i got 80 billz i get my car back fri from the shop
Old Jul 7, 2004 | 02:51 PM
u getting the dents taken out of the car from ur mom hit u ..... same color
Old Jul 7, 2004 | 08:10 PM
Bumpin Expo's Avatar
Reppin' the 813
wal mart has wires mad cheap, wire is wire i dont care what people say
As for wiring everything, its so easy.
Installdr.com
Shows you diagrams step by step with pictures how to install a head unit. As for hooking up the amp and running the wires I think is like 50$ at CC
Old Jul 7, 2004 | 08:38 PM
RkSport's Avatar
ya i need a wire harness/adapter i think to from my cd player the wires are diff.. how much would they charge me for wires at CC
Old Jul 7, 2004 | 08:57 PM
kpr10is's Avatar
Maximaniac
If you have a pioneer, alpine, panasonic, sony, or jvc deck, CC can sell you 2 harnesses so that the radio and the car become plug and play. Otherwise, just get the harness for the car, and match up the wires from that harness, color by color, to the ones coming out of the deck. The harnesses are $16.99 a piece. Dash kits are $17.99 and antenna adapters are $12.99, but an eclipse shouldn't need either. CC might tell you you need a dash kit, and they probably sell one, but just ISO mount it (use the screws that come with the radio, and the factory metal mounting brackets behind the radio).
Depending on the amp size and how much current it draws, either get a 4-gauge or 8-gauge wiring kit. If I were you, unless you are buying the 2 harnesses from CC to make the radio plug and play, then I wouldn't buy amp kits from CC. Just go to a custom shop, youll probably save like $30...or get the power kit from walmart and replace it with a better RCA cable, which for Stinger stuff, you can get a drone series RCA (their lower one) for about $13. It all depends on how all out you want to go, and if you ever plan on getting a bigger amp in the future, go with 4 gauge.
By the way, Curtis your slackin lol, CC charges $61 to install an amp/subs, not $50.
Good luck
Kevin
Old Jul 7, 2004 | 09:02 PM
kpr10is's Avatar
Maximaniac
P.S. The harness from CC for your car should be MET 707001, unless its an 89-94 in which case its MET 701743. If youve got the 00-03 with the infinity system, its gonna be a bitch because the antenna wire goes to the amp, not the head unit, so you gotta run new wires from the amp to the head unit, not to mention if you want to bypass the amp to use the head unit power.
Kevin
Old Jul 7, 2004 | 09:16 PM
RkSport's Avatar
its a 96 i need everything how much would it cost if i brought it too like CC and had them install everything and like bought the wires there and stuff.. ya i need 4 guage.
