crossover settings?
ok so i want to wire my components and obviously there are 3 ways to do so. 1st, input to low pass and output to speakers. 2nd, input to low pass and high pass from the same channel of amp, output to speakers and adjusting the crossover to "biwire". 3rd, input to hi and low pass from different amps and adjusting the crossover to bi-amp. now i have a 4 channel amp to power the components and a set of 6x9's. would i notice any difference if a wired it as biwire over wiring it with only low pass input? why?
Not really sure what you're explaining...but the normal way would be to run your amp at full range, output to an external x-over and then onto the tweet and mid.
Originally posted by kpr10is
Forget the stereo, invest in writing and english classes
jfwy
jfwy
. I just came form a stereo shop, he told me it was his first time to see that kind of crossover! i guess it's time to do the wiring both ways and see what's gonna happen.
well if u have 4 channels run it all seperate but if u only have 2 i would say the bi wire way it says its a little better right? (just skimmed threw) cant hurt to try them both out
yeah true, i have a 4ch abut i have 6x9's also. I'll do the biwire, but i dont feel like wiring the whole thing again (since the crossovers are in the front), am going to split the wire for the other input and tell you if there is any improvement.
yeah that's what i thought and thats why am going to split the wire or connect both of the inputs together. that should be the same except for the fact that it isn't going to be concidered as a bigger gauge wire.
