? for the guiy with the eclipse or ne1
if you want to replace them you can use the wires that are hooked up to the fac. tweeters, they jump off the door speakers, or you might need to go to the fac. amp witch in your car i think it's under the pass seat i dont know what color wires are just match them to the wires that are on the back off the fact. tweets, or if u have an after market radio you can run new wires from the radio to the tweeters thats prety easy,
Iam a car stereo installer. if you have stereo questions you can Email me willthisfitinyrmouth@hotmail.com
or get me on aol instant messenger dirtybird097
Actually, they're not even technically "tweeters". They're small speakers (3.5" I think). If you've got them up there, that means you've got the factory Infinity system, in which case you're going to want to bypass the factory amp if you want an aftermarket HU. I got a 6.5" component system (tweeter, mid, xover) and just removed the small dash speaker from the metal grill, and rigged up the compnent system's tweeter in it's place (ran new wiring from the dash location to the xover). The mids replaced the door speakers. Everything in factory locations, and out of prying eyes, without compromising too much sound quality.
is it hard to rewire the small speakers if i threw n some new 1s ??? or is there a way to liek splice n to the old wires from the harness and iono y i have that then cuz i didnt have the infinity system n my car
its me with the red eclipse from monday i was thinking of doing what u were saying and selln the 5*7s but iono if its going to b real hard if so screw it...........1 guy said it was easy but iono
All you need is a long flathead screwdriver to pop the grill/speaker out, extremely easy. You could use the factory wiring if you figure out which wires lead to it on the other end, but I found it easier to just drop in some new wire. Just feed it down through the opening and out the underside of the dash...then onto the HU area.
