Alpine TypeR
Old Apr 20, 2004 | 06:48 PM
GLintch's Avatar
DubLove
Default Alpine TypeR
Anyone got one?
Any one know the best amp for it?
And how to bridge a freakin Sony 800W amp ?
GLiNTCH
[ 07 GTI DSG UGrey ]
Old Apr 20, 2004 | 08:47 PM
TBSpyder's Avatar
In the car audio world, there is no "best". And you bridge an amp by using the positive of one channel and the negative of the other (assuming it's a 2 channel amp).
Old Apr 21, 2004 | 04:06 PM
boosted2's Avatar
Ive got one... but its in my room... still in the box
Old Apr 21, 2004 | 05:20 PM
kpr10is's Avatar
Maximaniac
my friend has 3 type r 12s in his rodeo, powered by the Alpine MRD-M1000. Too loud...drowns out the mids and highs. But the bass sounds real good.
Bridging all amps is basically the same, as John said, but when you wire the subs with the amp, make sure you dont go below the minimum ohm load the amp can handle. I blew up a sony xplod 1000 watt amp on my friends 2 12's cuz i thought it was 2 ohm stable.....its sony xplod...what was i thinking (sry GLintch)
wiring diagrams: http://www.jlaudio.com/tutorials/wiring/
Old Apr 22, 2004 | 05:21 AM
GLintch's Avatar
DubLove
Default well...
I got a 475w rated [Fozgate] powering that sub now...
I just want more prower and sony claims to give 800W peak nad about 400W RMS - which is what i need.
Alpine TypeR is 400W RMS
Thank you I already got one 10' TypeR in a ported box fron CC - for unbelivable $177 with a box and warranty for 2 years!
Any one know how to tell if it's a 2ohm or 4ohm ???
I had a shop that i am not gopnna name hook up my rca to only one of the rear speaker wires - and that;s why i am havin trouble with my sony amp.
rca output was too weak - so rewire of the converter box is coming up.
GLiNTCH
Old Apr 22, 2004 | 10:18 AM
TBSpyder's Avatar
You need an aftermarket HU. IMO, it's the first step in any system. I've yet to hear a decent sounding system on speaker level inputs. As far as the amp is concerned, Sony is lower end in the audio world...unfortunatley, the amp probably doesn't even put out what it's rated at. The RF (I'm assuming that's what you mean when you say "Fozgate") amp is probably better. First things first though, get an aftermarket HU and you'll hear a major difference.
Old Apr 22, 2004 | 10:37 AM
kpr10is's Avatar
Maximaniac
Also, Alpine Type R 10's and 12's are dual 4 ohm, so when you wire just one of them, you'll either have a 2 or 8 ohm load.
So check the minimum ohm load the RF can handle, if its 2 ohms then stick with that amp, cuz ull most likely blow up the Sony amp at 2 ohms.
Old Apr 27, 2004 | 07:31 AM
GLintch's Avatar
DubLove
thnx - i am returning the amp anyways - it's a $300 amp and i got it for $150 from Sears - since thayre are going away from car audio
ANy one wnat it ? a Xplod 800W amp for $150 ? call me at 813-843-9048
GLiNTCH
Old Apr 30, 2004 | 11:38 AM
XsF-JDM's Avatar
sony car audio is horrible, apn mrpm350 is a bad ass amp to go with type r 10's or 12's or the mrdm301 is good too, but i'm sayin screw type r's and i'm savin up for somethin even better type x's components are expensive as hell on those and the subs will prolly be too.
