Alpine Type R vs Alpine Type S
Old Apr 6, 2004 | 07:41 PM
Nate's Avatar
TR Balla Donor Supreme
Default Alpine Type R vs Alpine Type S
Type R Specs:
Specs:
General-Subwoofers
Diaphragm Material : Kevlar Reinforced Pulp
Magnetic Weight : 89.4oz.
Mounting Depth (top mount) : 178mm (7”)
Mounting Diameter (top mount) : 275mm (10-7/8”)
Recommended Box Types : Sealed/Vented/Bandpass
Recommended Sealed Box Volume : 0.7 – 1.0 cu. ft.
Spider Material : Nomex
Voice Coil Diameter : 50mm
Power Handling
Power Handling Capacity (Peak) : 1000W
Power Handling Capacity (RMS) : 300W
Thiel Small Parameters
Coil Height (Hvc) : 36.7mm
Cone Area (Sd) : 467.59 sq. cm
D.C.Coil Resistance (Re) : 1.8 ohm + 1.8 ohm
Electrical Q (Qes) : 0.40
Equivalent Suspension Stiffness (Vas) : 58 liters(2.04cu.ft.)
Free Air Resonance (Fs) : 27Hz
Frequency Response : 24Hz - 1kHz
Gap Height (Hag) : 10mm
Impedance (Nominal) : 2 ohm + 2 ohm
Inductance (Le) : 2.41mH at 1kHz (0.84mH at 20kHz)
Linear Excursion (X linear) : 13.35mm
Maximum Excursion (X peak) : 26.7mm
Mechanical Excursion (Peak-to-Peak) : 55mm
Mechanical Q (Qms) : 8.68
Sensitivity : 87 dB/W/M
Total Loudspeaker Q (Qts) : 0.38
Type S Specs:
Specs:
General-Subwoofers
Diaphragm Material : Aluminum Coated Poly and Kevlar Reinforced Pulp
Displacement Front Mounted : 0.095 cu.ft.
Displacement Rear Mounted : 0.123 cu.ft.
Frame Design : Deep Draw with Vented Leg/Spider Plateau, Integrated Terminal Landing
Gasket Design : Injection Moulded Hidden Screw Design with Front/Rear Sealing
Magnetic Weight : 72oz.
Motor Structure Configuration and Pole Geometry : Extended Dual Flare Pole Vent Compound Radius Curve
Mounting Depth (top mount) : 164mm (6.6”)
Mounting Diameter (top mount) : 274mm (11”)
Optimum Sealed Box Volume : 1.25 cu.ft.
Optimum Vented Box Volume : 1.5 cu.ft.
Recommended Sealed Box Volume : 0.85 – 1.5 cu. ft.
Spider Material : Nomex®
Surround Design and Material : High Excursion Tapered Half-Roll, Injection Moulded Santoprene®
Terminal Type : Heavy Duty 8ga. Push with Housing, Banana Plug Jumper
Vented Box Volume Range, Vent Diameter Length : 1.25-2.0 cu.ft,, 4" ID x 12" Long
Voice Coil Design : 4-Layer Dual Voice Coil
Voice Coil Diameter : 38mm (1.5")
Power Handling
Power Handling Capacity (Peak) : 900W
Coil Height (Hvc) : 33.8mm
Cone Area (Sd) : 485sq. cm
D.C.Coil Resistance (Re) : 1.8ohm + 1.8ohm
Electrical Q (Qes) : 0.65
Equivalent Suspension Stiffness (Vas) : 54 liters(1.9cu.ft.)
Free Air Resonance (Fs) : 31Hz
Frequency Response : 26Hz - 1kHz
Gap Height (Hag) : 8mm
Impedance (Nominal) : 2ohm + 2ohm
Inductance (Le) : 2.31 mH / 0.78 mH
Linear Excursion (X linear) : 12.9mm
Magnetic Linear Excursion (Xmag) : 14
Mechanical Excursion (Peak-to-Peak) : 52mm
Mechanical Q (Qms) : 12.63
Total Loudspeaker Q (Qts) : 0.62
Which one would you go with? I am going to put 4 in my trunk. I can get the Type R's for around 120 a sub, and the Type S's for around 95 a sub, what would you reccomend?
Thanks,
Nate
Old Apr 7, 2004 | 05:38 AM
Bumpin Expo's Avatar
Reppin' the 813
go wit the type S
Why?
More durable, looks so much better, basicly the same as the R, and they are cheaper
I was going to upgrade my type E's that i currently have to R's so I did my homework. Come to find out Type R's are known for their cones to seperate from the surround. Then i went up to CC and asked their opinion and they said the same thing, customers always come back saying the surround came unglued from the cone. So i was like damn. So I came back home and did some more homework. Found out S's are basicly the same as the R's but much more durable. Plus i love the way the new aluminum ones look. So i think thats the route im going when i get enuf money for a new amp and subs. Also where u gettin them, ebay?
Old Apr 7, 2004 | 07:20 AM
Nate's Avatar
Nah, I work at Circuit City, so im probably gonna get them there.
Old Apr 7, 2004 | 10:32 AM
Derek's Avatar
Whitey on the Moon
they have type s's at circuit city?
Old Apr 7, 2004 | 12:44 PM
TBSpyder's Avatar
I vote neither. You could pick up a single 12 or 15 of a different brand and blow all 4 of those out of the water, plus not have to worry about multiple amps and a massive enclosure....
Old Apr 7, 2004 | 01:35 PM
Reppin' the 813
u could do this too
and no they dont have type S at CC in stock, special order
Old Apr 8, 2004 | 03:07 PM
BRET's Avatar
F*ck Tom Brady
or buy 1 solo x 18
Old Apr 8, 2004 | 08:02 PM
Reppin' the 813
Originally posted by VIRGINiaGIRLSpwm
or buy 1 solo x 18
I would think if hes going alpine hes lookin more for a sq setup
Old Apr 9, 2004 | 04:42 AM
TBSpyder's Avatar
No offense, but I wouldn't consider Alpine speakers SQ or SPL...they're more of an affordable everyday speaker for your average joe. Same goes for most any of the brands that offer such a wide array of audio equipment (Sony, Panasonic, Pioneer, Kenwood, ect.).
Old Apr 9, 2004 | 07:38 AM
Reppin' the 813
im not gonna start a fight
I bed to differ. I think Alpine subs are geared more towards the SQ range. Sony, panasonic, pioneer, kenwood are all shitty when it comes to subs. ive heard them all besides panasonic subs and didnt like them. I would say alpine falls into the same catagory as kicker (not the l7s) Geared more towards sq but still can get loud
