Need some help.
Old Feb 20, 2004 | 06:15 AM
Graves's Avatar
Default Need some help.
Ok I just bought a pair of 10's off Eli. THey are Audiobahn AW1006Q's , same as the AW1006T. I am running a JBL BP1200.1 amp for the subs. I looked up how they should be wired and keep getting 2 or 3 different ways they should be hooked up. I got em running now Series Parallel at a 4 ohm load. Being mostly audio stupid can you guys suggest how I should have em done up. I am on the road tonight to New Orleans more than likely so if you could drop me a line on Aim or leave a message/link to an idea of what I should do.
Old Feb 20, 2004 | 10:05 AM
93ex's Avatar
Just Ledoux it!
whats the vc configuration? im guessing dual 4 ohms
OR
Old Feb 20, 2004 | 10:08 AM
Graves's Avatar
Thats how I have em wired now. Just wanted to make sure before I blew em all to hell. There was way too many options on how to set it up.
Old Feb 20, 2004 | 10:20 AM
Graves's Avatar
Ok got an email from Audiobahn that said I need to run them different. They said I need to run it Parallel-Parallel to achieve the 1 ohm load.
Old Feb 20, 2004 | 12:46 PM
93ex's Avatar
Just Ledoux it!
you just said you have it wired to 1 ohm but now you need to wire it to one ohm???
Old Feb 20, 2004 | 02:24 PM
Graves's Avatar
I had it in a series not parallel. Sounds better now. Off I go. . . . . . .
Old Feb 20, 2004 | 02:29 PM
TBSpyder's Avatar
Wow...the confusion.
Old Feb 20, 2004 | 06:58 PM
eli's Avatar
eli
im curious to hear how they sound. i only used em once in a buddies tahoe and couldnt ever find the right amp. im curious....... hit me up when u get back or ill see u at a meet or something.
eli's Avatar
eli
also thank u for buying em i needed some cash.
