lets talk ohm's
Old Feb 1, 2004 | 08:08 AM
Solar Specialist's Avatar
SOLAR-SPECIALIST.COM
Ok, so your amp has to be rated at the same or lower ohms than your sub? Sorry for the dumb questions.
Old Feb 1, 2004 | 08:14 AM
aaron1017's Avatar
is not Rotarded anymore!
Originally posted by TBSpyder
I think it's safe to say the difference is almost impossible to pick up by ear though, especially with subs/low frequency bass.
Heeeehehe, I know. It might matter a little bit to very picky people if they are using it for their comps.
Otherwise I wouldn't worry about it for a subwoofer.
LS1/T56 Heads Cam 1994 FD
Old Feb 1, 2004 | 08:23 AM
TBSpyder's Avatar
Yes, basically. But the ohm load your sub(s) produce changes considering how you wire them. If you're looking for a sub amp, my best recommendation would be to look for a mono class D amp, stable to 1ohm....you'll be pretty safe with about any combo you throw at.
Old Feb 2, 2004 | 07:30 AM
Well I was going to wire 2 channels, one to each voice coil, to my sub.
Old Feb 2, 2004 | 07:31 AM
Heres the sub I'm getting.
http://www.edesignaudio.com/ep2/12k.htm
Old Feb 2, 2004 | 07:36 AM
TBSpyder's Avatar
The amp would see a 4ohm load in that case.
Old Feb 2, 2004 | 08:34 AM
  #17 (permalink)
93ex's Avatar
Just Ledoux it!
pshhaw class a/b who needs it
