Car Battery Question
Old Dec 29, 2003 | 11:28 AM
import6666's Avatar
GSXR
Question Car Battery Question
I have a big system in my car and I want to run an auxilary battery that would get charged by the alternator but would be isolated from the main battery (not connected to it).
I am not exactly sure how to do this but I think I am supposed to connect the ground going to the main battery to the backup battery. Am I right or is there another way of hooking this up?
This probably isn't the correct place to post this but this section gets the most exposure to the public. Can anybody help?
Old Dec 29, 2003 | 11:47 AM
Leonard's Avatar
OUCH!!!
if it's part of the charging circuit, it's part of the circuit....
What exactly are you trying to accomplish with the 2nd battery?
Old Dec 29, 2003 | 11:49 AM
import6666's Avatar
GSXR
I want to have an extra battery that will only power my amplifiers and will not drain power from the battery that starts the car but I also want this extra battery to be charged by the alternator.
Old Dec 29, 2003 | 12:41 PM
MDIFYTD's Avatar
Uber lurker
So you have issues with your accesories(power windows, lights...) while your system is drawing power? Or do you want to play your system for extended periods of time with your car off?
Ill say i go by His and Al's thoery of "Your getting sprayed" Doesnt matter what it is. Grandma in the 1982 LTD is gettin the bottle.
Old Dec 29, 2003 | 12:43 PM
Leonard's Avatar
OUCH!!!
Put a relay inbetween the alternator and the 2nd battery that is triggered by a switched source off the ignition. While the car is running, the relay will close and it will be one combined circuit (and thus get charged and when the car is off, the relay will open and disconnect the two circuits leaving you to drain the 2nd battery.
Old Dec 29, 2003 | 01:14 PM
93ex's Avatar
Just Ledoux it!
battrey isolator or diode
Old Dec 29, 2003 | 02:58 PM
Josh's Avatar
Dr. Doom
yup.
Old Jan 4, 2004 | 08:45 PM
China's Avatar
Communist
Default Re: Car Battery Question
instead of running a battery cable all the way from the hood to the trunk, y dont you just ground out the extra bettery to the body? find a good sized bolt, get some sandpaper, and ground out somewhere to the trunk to complete the circuit. and invest in fuses.... fuses are always a good thing
china
Old Jan 5, 2004 | 07:31 PM
QuickSC2 3HT's Avatar
Auxilary battey is a good thing but are you even running a top notch Optima battery now or just a regular one. I bought an optima red top and i can run my 1600W SPL amp for a while with the car off and still have enough juice to start the car.
'02 Subaru WRX 2.5L, SR40 turbo, MRT TMIC, RA gears, ACT clutch & flywheel
'06 Chevy Cobalt SS GM Stg 2 G85 lsd
'94 Acura Integra GSR sold
'99 Isuzu Rodeo 4x4 2" lift, Procomp 9000 shocks, 20" Procomp Knight Khrome wheels sold
'92 Acura Integra RS sold
'04 CRF450R '86 TRX250R
Old Jan 6, 2004 | 12:20 AM
93ex's Avatar
Just Ledoux it!
yeah because its not 1600w at a constant rate
