The challenge begins
Guest
Posts: n/a
I have all of this stuff for the new setup -
Eclipse 5506 Head Unit
(2) Eclipse 8 Disc CD Changers
(2) Eclipse 8710.4 10in Subs
(2) Zapco EQ30-SL 30 Band Equalizers
Zapco SX-SL Equalizer
Zapco Z400C4-SL 1 ohm stable Competition Amp
(2) Focal 130KS Mids and Highs
Voltage and Amp Temperature Gauges
Lightning Audio Wiring, Capacitor & Blocks
Custom Amp Cooling w/ Exhaust Port
Custom Made Vinyl Panels and Plexiglass
Custom Made Carbon Fiber Trim
Custom Made Neon Light Enclosure
Custom Made Kick Panels
+ All the wiring.. and its going to be a MESS...... The Zapco setup comes with converters which converts the wiring to telephone looking wire that goes to all of the EQ's.. the 30 band EQ's are for fine tuning the left and right, then the main EQ of course.
I think the main pain in the ass will be splicing in for the converter... I think I will be starting on the stereo installation on next weekend....
i still need to read up on installation to see from where the wires go.. like cross over, then to amp, etc.. this is going to suck
Damn $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$
I can only dream!!!
I tryed an all eclipse system once.. Couldnt find the stuff at the right price.. I have the dvc 12's alu-cone and a 4 channel amp. The rest is other brands..
pm me when you get pictures
I can only dream!!!
http://www.jonhertel.com
Originally posted by SupraKid
yea since i work for it obviously
enough of that shit already damn
i was thinking maybe i could find help here
enough of that shit already damni was thinking maybe i could find help here
Ok I will show you a picture of the wiring tomorrow and you will change that orgasm thought if its up to you to install it... stop being a dick man, some support we have here on the audio section.....
The best system in the world will sound like ass if you don't install it right. If you're intimidated by the task you may want to take it to a pro...
Are you building kicks? If so, have you ever done it before because that's no easy task?
Have you eq'd a system before?
Do you have reference material for both imaging and tonal accuracy?
Not to rain on your parade man I'd just hate to see that fine equipment used to anything less than it's full potential.
Ill say i go by His and Al's thoery of "Your getting sprayed" Doesnt matter what it is. Grandma in the 1982 LTD is gettin the bottle.
