Need specs on this amp
Old Aug 31, 2003 | 09:59 PM
93ex's Avatar
Just Ledoux it!
heres what i found
Ok, anyway, the amp is a soundstream continuum. This was a quite limited production to celebrate soundstreams anniversary (forgot which one ..25th?). I think there were only 5-10 sent to my state. Anyway, it basically has everything you would ever need for an incredible system.
POWER: 75 X 4, and 300 X 1. Of course, that is VERY conservative because soundstream doesn't use voltage regulation, and these numbers are for 12V, and most cars run at more like 14V. Anyway, those numbers are RMS values, NOT PEAK. Those numbers are also for a 4ohm load. This amp is capable of a 1/infinity load impedance. I'm pretty sure thats what the manual says even. Basically as many speakers are you can stick in parallel, this amp won't quit on you.
CROSSOVER: This amp has the best active cross-over built in that I've ever used. complete control, 3-way, 18db/octave. This isn't your average lowpass and highpass, you have alot more control than usual, and the ability to do bandpass.
FINISH: The heat sink is polished aluminum. Looks great.. There are only a few polished soundstream amps, and they are all special editions or expensive as hell.
Old Aug 31, 2003 | 10:38 PM
93ex's Avatar
Just Ledoux it!
Originally posted by rangcrx
wow a four channel that can bridged mono wow thats new to me
its a 5 channel amp, 4 channels for fronts/rears, and 1 for subs, lots of companies do this.
and what? yorue getting rid of the MTX?
Old Aug 31, 2003 | 10:51 PM
rangcrx's Avatar
engine building &best
not sure mite be keeping it but i need more to power those that amp will not do it unless i bridge it but but still thats not much power even from Mtx im thinking on going with the new KICKER SX1250.1 you ever heard one
i love AUTOZONE
Old Aug 31, 2003 | 10:56 PM
93ex's Avatar
Just Ledoux it!
nope, sure havent, maybe the arc audio 4000XXK is more your liking
Old Sep 1, 2003 | 02:23 PM
93ex's Avatar
Just Ledoux it!
Originally posted by Vapor
awesome, just the info i was looking for. Thanks a lot Jesse
youre welcome, its what I'm here for
