FS: Fully Built Darton sleeved LS block!!!
Old Nov 4, 2012 | 10:25 AM
91EF919's Avatar
Default FS: Fully Built Darton sleeved LS block!!!
Fully built darton "dry" sleeved block with only 1200 miles on block due to car getting totaled..
[ATTACH=CONFIG]192782[/ATTACH]
Everything is new n have papers to prove.
CP 9.0:1 pistons
Eagle H beam rods
Comptech block guard
ACL bearings
ARP head n main studs
New ITR water pump oil pump n timing belt
Micropoloished n balanced ls crank
All new oem seals
Everything was hot tanked checked clearances n all in spec. Cw pence built this block. More info hmu at 3213325186
Price $1000
My Car Gets Mad 5500k
Old Nov 4, 2012 | 04:10 PM
juiced2ndgenteg's Avatar
What bore size? Also, if cash was present, would you allow me to inspect the bearing and crank surfaces. Before cash and block changed hands?
Old Nov 5, 2012 | 01:34 PM
lawjdl16's Avatar
Dry sleeves are stock replacement sleeves, not really good for more Horsepower than stock, usually used to repair a cracked stock sleeve without going full out MID sleeves. If they are dry, flanged sleeves they are a slight improvement to stock but he didnt say flanged, but they would appear to be stock sleeves
Old Nov 5, 2012 | 02:43 PM
^if you crack a stock sleeve then dry sleeves won't work. You need the aluminum casting to be uncracked to put dry sleeves in. When you crack a sleeve the aluminum casting around the stock sleeve cracks too. Your statement is really bad info.
Old Nov 7, 2012 | 12:25 PM
timael_13's Avatar
Do you still have this block?
Old Nov 8, 2012 | 05:58 AM
jdmem205's Avatar
So how much power can this handle?
91EF919
For Sale/WTB Honda & Acura
10
Oct 28, 2012 12:24 PM
91EF919
7
Aug 14, 2012 03:53 PM
g3t_Sum
9
Nov 28, 2007 01:23 PM
DONT SLEEP
10
Nov 26, 2006 03:08 PM
