95 240sx For Sale $2600
240SX For sale
Year: 1995
Miles: 110,174
Price: $2600 Firm
I am not selling this car cause I have to.
Auto and everything is oem/stock except shocks=KYB GR2's that dont leak/feel good
This car is solid, doesnt vibrate/shake/feel like its gonna fall apart. Runs great,will sit there and idle until it runs outta gas,although the bottom timing chain tensioner+guide etc. is making the typical noise, but only at startup, goes mostly away after like 5-10 seconds. You can tell a kid hasnt gotten a hold of it and ruined it like most are on here.Everything is there,oem speakers even has the little plastic tabs that cover the screws for the door handles. Great dd/project/starting platform/drift w/e your little hearts desires.
PROS-
-Original black paint in good shape overall except rear bumper has typical cracking slight peeling but its not that bad.Also front bumper, hood, pass fender are painted black not original.
-Everything works in this car, everything,horn,dome light,windows,sunroof,cruise,etc...
-Ice Cold A/C!!!
-Power steering pump doesn't whine
-Interior is very nice and clean besides door panels/pass seat/dash/radio bezel. Carpet is nice!
-KYB GR2 Shocks that feel good, and dont leak,thats the only non oem part on the car
-Sunroof works, doesnt leak,and the weather stripping/trim isnt f'd up like most
-NO RUST!!!
-OEM spare tire
-Original good running KA with no leaks and no smoke
-Windows fitment is perfect, they are not haggard when lowering/raising,both motors work,rear view mirror is not loose and moves every time you hit the gas, nice and tight like virgin!
-Brand new battery and ngk spark plugs
Cons-
-No radio, thats how I got it, but the harness is there and in tact, not f'd up
-Windshield has Small 6" crack that is very unnoticeable at the very top on the d/s. Not illegal, you will not get messed w/by the man
-Car was in wreck on p/s. Does not affect the frame/driveablity/etc. at all. Its been pulled out pretty good, but to be done the 0 right way a new core support as well as bottom support where the tension rod brackets bolt up(They are fine though). As a result of this the p/s headlight sits a tad bit back, but overall its not that bad/noticeable.Airbags replaced!
-Will state again. Dash cracked,radio bezel cracked,door panels both have a hole drilled by speaker grilles for tweeter and d/s panel is missing speaker grille,p/s seat is from an s13 LE its white and it has scratches/rips,not totally terrible though like a dog ate it or something
-Front grille you will notice in the pics is not there,its in the trunk, you get with car. Cant mount/secure it b/c the front buper support+retainer is not there. Bumper is supported in the middle with a custom bracket/mount that I made, it works pretty good.
If I get asking price I will include a mint auto trans+flywheel+tq converter. Guaranteed good working no problems that way you can either sell it or have a good spare setup laying around. Also if I get asking price, If you source an s14 that has a good front rad support etc... I will cut whats needed and fix the front that way. Or you can bring it to me precut and I will do all the work to make fix it 0 correct for a couple hundred maybe like $200 which is cheap as it would cost you upwards of $1000 easily at a body shop or some dipshit that isnt even going to do it right. As stated before, its not bad now and I wouldnt worry about it but the offer is there.
Year: 1995
Miles: 110,174
Price: $2600 Firm
PROS-
-Ice Cold A/C!!!
-NO RUST!!!
-OEM spare tire
Cons-
-Julien
-Julien
^^^ttt^^^
01' HONDA CBR929RR for sale!!!!!
91' 240sx hatch KA24DE for sale after paint is finished!!!!!
89' 240sx coupe RB25 project car,
93' 240sx coupe RACE CAR,
90' 240sx hatch parts car,
93' Isuzu 4x4 work truck.
