FS 95 civic turbo eg coupe
Looking for good offers on my eg turbo with a/c 300 whp.
Here are the specs
JDM CORNERS
8K HIDs
LOWRED
FRONT CAMBER KITS
SI RIMS
DUCKBILL
GATOR AXELS (VERY GOOD FOR BOOSTED CARS)
FULL STOCK CIVIC INTERIOR IN VERY GOOD CONDITION
6 DIFFERENT DENZO GAUGES:
1. FUEL PRESSURE
2. WATER TEMPATURE
3. BOOST GAUGE
4. OIL PRESSURE
5. EXT TACH
6. OIL TEMPATURE
NEW TIRE RODS
NEW LOWER AND UPPER BALL JOINTS
MOTOR:
EAGLE H BEAM RODS
ACL BEARINGS
ARP ROD BOLTS
ARP HEAD STUDS
JDM B16A HEAD
ITR VALVE TRAIN
TITANIUM RETAINERS
CROWLER STAGE 1 CAMS
PORT AND POLISHED
AEM 2 ADJUSTABLE CAM GEARS
STR FUEL RAIL
WALBRO 255 FUEL PUMP WITH REGULATOR
1300CC FUEL INJECTORS
OEM ALTERNATOR
OEM STARTER
GSR LSD TRANNY
GARRET TURBO KIT
2 BLIZ BLOW OFF VALVES
NGK 8.5 MM SPARK PLUG WIRES
STAGE 3 CLUTCH AND FLYWHEEL
HONDATA S300 ON CHIPPED P28
Redline is set at 8500
Hasport Solid Motor Mounts
APEX TURBO TIMER
BOOSTING 16LBS BUT COULD GO HIGHER IF WANTED
2.5in Intercooler Piping
4in Intercooler
AC BLOWS VERY COLD
CONS:
CRACK IN WINDSHIELD (GOING TO TRY TO REPLACE BEFORE I SELL IF MY INSURANCE GOES OUT THERE QUICK ENOUGH)
NO RADIO
NO POWER STEERING
NEEDS TIRES AND ALIGNMENT RIGHT AWAY
COULD USE A PAINT JOB ON THE FENDERS AND THE HOOD (IF I KEEP IT LONG ENOUGH ALSO WOULD BE DONING THIS AND THE PRICE WILL GO UP)
Give me a text at 4075298379. offers please be above 4900[IMG]
[/IMG]
Here are the specs
JDM CORNERS
8K HIDs
LOWRED
FRONT CAMBER KITS
SI RIMS
DUCKBILL
1. FUEL PRESSURE
2. WATER TEMPATURE
3. BOOST GAUGE
4. OIL PRESSURE
5. EXT TACH
6. OIL TEMPATURE
NEW TIRE RODS
MOTOR:
EAGLE H BEAM RODS
ACL BEARINGS
ARP ROD BOLTS
ARP HEAD STUDS
JDM B16A HEAD
ITR VALVE TRAIN
TITANIUM RETAINERS
PORT AND POLISHED
STR FUEL RAIL
OEM ALTERNATOR
OEM STARTER
GSR LSD TRANNY
GARRET TURBO KIT
APEX TURBO TIMER
4in Intercooler
AC BLOWS VERY COLD
CONS:
NO RADIO
NO POWER STEERING
[/IMG]
mofobucs
Dec 23, 2008 05:47 AM
