built jdm b18c type r swap, for test waters, everything fresh!!!!!
Old Oct 6, 2010 | 11:02 AM
chucky12si's Avatar
Default built jdm b18c type r swap, for test waters, everything fresh!!!!!
just test water my swap
b18c jdm type r
receipts for everything
block
everything is blue printed
new piston rings, and has been gapped
fresh hone
block has been decked
block cleaned
acl crank bearings, and rod bearings
new crank seal gaskets
new oil pump gaskets
new oil pan gasket
new water pump gasket
new head gasket
arp head studs
head
shaved
hot tanked
race port and polish
5 angle valve job
skunk2 valve springs and retainers
skunk2 pro series cam gears
skunk2 stage 2 pro series cams
hondata intake manifold gasket port matched
edelblock intake manifold port matched
aem fuel rail and gauge
b&m fuel pressure regulator
spoon spark plug wires
new valve cover gasket kit
new honda timing belt
65mm type r throttle body
tranny
type r with 4.9 final
act clutch set up stage2
fidanza flywheel
dyno tuned computer by columbia 215 to wheels before fresh rebuild and without cam timing, should be 220-225 with retune
p.s, jus test water
Old Oct 6, 2010 | 11:13 AM
team_type_1's Avatar
Thumbs up
i got a eg si hatch 2 d series block n head n a y8 tranny b16 axels all i got lol BUMP FOR NICE SWAP
Old Oct 6, 2010 | 11:21 AM
chucky12si's Avatar
thanks
Old Oct 6, 2010 | 11:28 AM
chucky12si's Avatar
Old Oct 6, 2010 | 11:38 AM
FoxHondaRider's Avatar
Registered Hater
Those are some impressive numbers for just headwork, GLWS
Originally Posted by *JamReX*
The only thing worse than fucking ricers, VW .... who think theyre style is somehow supreme to all others.
Honda builds go from yay to gay in the matter of a K.
Old Oct 6, 2010 | 12:51 PM
dolpihnsforever305's Avatar
shared_pm me a price
Old Oct 6, 2010 | 03:39 PM
chucky12si's Avatar
yeah i know cams, full bolt-ons and port polish makes a difference
Old Oct 7, 2010 | 07:14 AM
chucky12si's Avatar
Old Oct 7, 2010 | 12:51 PM
chucky12si's Avatar
Old Oct 7, 2010 | 01:52 PM
JDMjunkie's Avatar
Looks like manny88 old motor
TampaRacing's DEAD!!
