My CX Hatch Build
Old May 8, 2010 | 04:51 AM
wakeking48's Avatar
Yes!!!!
Default My CX Hatch Build
I picked this car up from marktopia about 3 months ago and am finally gettin around to the build part. But before we get into that lets talk about the road to here. I found the car on TR and called mark, the car was listed as a 1993 Red cx ls swap with a misfire and flooding problem. He could not figure it out so he wanted it gone. I got it home and had nothin but problems.
It got a new:
-Walbro 255
-fuel filter
-dizzy
-master clutch cylinder
-slave cylinder
-injectors
-ngk spark plugs
-ngk wires
-Oil pan gasket
-valve cover gasket.
After all was done i took my old ecu out to a guy in the dade county area car ran great on the way, but then bam didnt want to kick back over? Sat for a tow truck for 5 hours to got home to find out the timing was way off.
Now i have been driving with no problems and decided to get my build on the road. So lets get started.
What she looked like when i first got her home
2001 King Ranch F.150 (sold)
1991 5.0 Ls mustang (sold)
1993 ls cx hatch (traded)
1995 b16 eg coupe (SOLD)
2007 Hyundai Tiburon (sold)
2006 Yamaha R6 (sold)
1995 jdm b20b integra (sold)
2006 Mitsubishi fp red evo (dd)
Old May 8, 2010 | 05:01 AM
wakeking48's Avatar
Yes!!!!
Now to the parts that will be used to construct her heart.
Bucket of fun
Block that will be used
Crank and block after machine shop
Both were re honed, have a super thick patroleum sittin on them to prevent rust.
Old May 9, 2010 | 07:49 AM
wakeking48's Avatar
Yes!!!!
I got my first package today
Brand new CTR pistons
ARP rod bolts
Nippon Piston Rings
Another set of b16a rods
Old May 9, 2010 | 09:22 AM
Secondz's Avatar
Built Not Bought
Oh damn... Do work son!
Old May 9, 2010 | 10:13 AM
wakeking48's Avatar
Yes!!!!
Oh i will be doin work my friend!
Just need to drop off the rods and pistons at the machine shop so they can get pressed. And drop off the crank so they can give me the prober rod bearings, Then i got to drop off the block for main bearings. And then botom end will be all done.
Old May 9, 2010 | 02:32 PM
honda_jdm's Avatar
cant wait to see some work done! gl with build.
TR"Old Skool EF"
Member #180
Old May 10, 2010 | 07:34 AM
wakeking48's Avatar
Yes!!!!
So i will be replacing my buddys clutch today so with the money he throws me im going to get this bottom end done hopefully :/. But idk if i want to run a b16 head or gsr? I have been leanin towards the gsr since it will give me a higher compression. But i will be doing a port/pollish and valve job soooo? Discuss!
Old May 10, 2010 | 11:02 AM
SLOASFUK's Avatar
yaaa boy fuk wat u heard
dont take your rods and pistons to united speed world. The mounted mine the wrong way. Blew my shit up.
sig by: skunkdsir
Old May 10, 2010 | 12:00 PM
integra's Avatar
90% grind 10% sleep
damn i hear good things about them too..
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old May 10, 2010 | 07:15 PM
wakeking48's Avatar
Yes!!!!
Thanks i will keep that in mind, but i found what i believe to be a ctr ecu and the guy said i can have it for 80 if i drive to daytona. What you guys think should i run it or just go with a gsr ecu?
