help?
Old Dec 11, 2008 | 06:45 AM
Billybong's Avatar
Default help?
Im taking my EG and going b series. it aw a d16z6 automatic and im swapping a b18a1 into it. There are so many routs i can go. but i kno im goin to boost it sometime around febuary. in that case i was thinking abvout goin ls/vtec but then i have to run oil lines and plug holes which i dont know much on how to do. so would it be better off to just get my acr running with a stock b18a1 and build and boost that? or is the ls/vtec realy going to make that much of a diffrence?
Old Dec 11, 2008 | 11:10 AM
Billybong's Avatar
Old Dec 15, 2008 | 07:01 PM
ghostofnyc's Avatar
N20 Whore
lsvtec will def make more power but there is nothing wrong with a ls on boost it depends on your budget.
F.D.L.R / Midnight Auto/ Induction Performance
RIP BOOGA
When the Green Light Drops the Bullshit Stops.
ALPHA TUNING For all of your tuning needs 813-443-5064 http://www.inductionperformance.com/
Old Dec 15, 2008 | 07:13 PM
tranceologist's Avatar
TR Shop Mod
n/a is fun. u run outa hp, then ur seeking more hp, but gota change the compression to take the boost.
lsv ur gonna get 30-40 hp. ur gonna have 2 run oil lines just the same as boost. u have to tune both set ups.
boost on a stock bottom b series is good for 300 or so hp b 4 u have put better parts in there.
theres a stock d series here on tr running 15 + lbs of boost on a superb tune.
g/l and enjoy !
Old Dec 17, 2008 | 05:28 AM
Alpha's Avatar
If you're on a tight budget I would recommend turbo LS. Especially if you're going to stick to the stock bottom end. Before even going turbo I would highly recommend compression testing and leakdown testing the motor. If everything turns out good buy and install ARP head studs before hand. Good luck!
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Dec 17, 2008 | 09:48 AM
Billybong's Avatar
thanx were can i get compression tested?
Old Dec 18, 2008 | 05:38 AM
Alpha's Avatar
Shoot me a pm. I dont mind compression testing it for you one day
* IP E-Mail
* IP Face Book
* IP Web-Site
