Group Buy: Bosch SATURATED (NO RESISTOR BOX) 1000cc Fuel Injectors
Old Nov 18, 2008 | 12:27 PM
Alpha's Avatar
Default Group Buy: Bosch SATURATED (NO RESISTOR BOX) 1000cc Fuel Injectors
Refer to https://www.tamparacing.com/forums/h...uys-girls.html for my testing and results of these injectors
We need a minimum of three people to get special pricing on these injectors. I've already quoted a few of you. In order to secure a spot I will need a non refundable $100.00 deposit unless the group buy doesnt go through
1) poorboy44 (DEPOSIT PAID)
2) Dean (PAID FULL)
3) Bobby (PAID FULL)
* They are a 48mm long body, shorter than normal injectors. The adaptor tops make them "normal" 60mm length and adapt them to 11mm (B series) or 14mm (K series) orings. The K series guys can run the injectors with no adaptors at all and they are the same length as the OEM rsx injectors so no spacers needed on the rail. These have a droplet size comparable to a 600cc Siemens injector and way better spray pattern and atomization than any other 1000cc injector on the market. The proper battery comp values are also provided with each set so you can set it up in your computer and have consistent a/f ratios as battery voltage fluctuates. Most other injectors don't offer that information at anything other than 1 voltage level.
* High Impedance, no need for injector drivers or injector resistors
* High pressure capability, All injectors will run comfortably at 100psi above 10v, flow will be increased by approximately 50% at 100psi
* High duty cycle, with a recovery time of only 1ms, all injectors will run up to 92.5% duty cycle at 9k rpm and 95% duty cycle at 6k rpm while maintaining linearity within 1%
* Excellent low pulsewidth response, linearity within 2% all the way down to 2ms, predictable response down to 1.5ms. Using a 3 dimensional battery comp table with Motec V3 software, low pulsewidth response can be linearized to practically zero flow.
* Good atomization, Droplet size of the 1000cc injector is comparable to the Siemens Mototron 60lb injector, and is far better than the Multec 95lb, Standard Motor Products (RC) 1000cc and Siemens 72 and 83lb injectors.
* Excellent consistency, no sets will require more than a 1% trim
* Ruler flat response, unmatched linearity means easy tuning and accurate compensations
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Nov 18, 2008 | 01:59 PM
Alpha's Avatar
poorboy44 is coming through tonight with deposit! Two more
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Nov 18, 2008 | 04:15 PM
flaco0018's Avatar
I cannot believe how good these injectors work! My car had never idled this way before. Alpha, thanks for the tremendous job you did on my car! ...and no more resistor box
10.6@136 k20
ALPHA TUNING For all of your tuning needs 7275051423 Induction Performance
BUILT BY KJ
Old Nov 18, 2008 | 04:18 PM
poorboy44's Avatar
TR Balla Donor Supreme
put my deposit in tonight
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
Old Nov 20, 2008 | 11:27 AM
Alpha's Avatar
We may have one more coming this week or weekend ...
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Nov 20, 2008 | 02:44 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
put me down.... I'll call you tomorrow so we can meet up...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Nov 20, 2008 | 07:14 PM
Alpha's Avatar
Give me a shout tomorrow and will meet up
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Nov 23, 2008 | 09:06 PM
TheRedDragon's Avatar
did u guys ever meet up?
ALPHA TUNED
Tuning, Builds, Assembly, Turbo Installs, Repairs and More
Old Nov 23, 2008 | 09:55 PM
Alpha's Avatar
Negative. I think he forgot to call me
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Nov 26, 2008 | 09:34 AM
Alpha's Avatar
We've met the group buy. Thanks guys Sorry to everyone who didnt jump on this. Back to normal pricing
* IP E-Mail
* IP Face Book
* IP Web-Site
