Need Si or Hf obd0 Injectors (stock)!!ASAP!!
Like the title says need theses asap and real cheeeep. Im in a down time and the car took a shit . Friend of mine gave me a set of obd1 injectors and said to trim out the inside so the clips will fit so i did and now it runs but bad and shoot out a shit load of WHITE smoke. another friend of mine told me that my ecu was'nt reading the injectors right because they where obd1 even thow they pluged in to my obd0 harness after i cut out the little pice of plastic so the clip would fit! Is there another thing wrong or do i need the stock obd0 injectors? if i need the injectors then Please somone help me out with a good deal or some insight on what my prob. realy is!
Thanx,
OldSchool Mike
Thanx,
OldSchool Mike
what your describing sounds like the typical user idiot10 error, when you changed the injectors, there are little black filters in the end of each top of the injector,these tend to fall out in storage ie: your dressor drawer or tool box! what most people who arent paying attension do is let them fall out and when they put em in the car there missing 2 or 3 of the filters, so it runs like shit cause the filter also restricts the fuel flow, look at the top of each injector make sure you got a little black insert in each one. That should solve the prob if your missing em then pull some from other injectors laying around and make sure all four in your car have em!
Call Me If You Have Any Questions Or To Make Me An Offer! Pm Me for My Number!
+1 minus the user idiot part
TR "Rep for Bumpin" CREW MEMBER #69 A.K.A #1TR "EG" CREW MEMBER #21 A.K.A #69
THE HATCH IS FOR SALE!!
"There’s a difference between knowing the path and walking the path"
