Explaining external and internal wastegates
Guest
Posts: n/a
Here is some info that can help most of you as to knowing what differences are between an Internal or an External wastegate. An internal wastegate is built in as part of the turbocharger's turbine housing. It consists of an flapper door that allows exhaust gas to bypass the the turbine blade, thus regulating the amount of boost created. An external wastegate is a separate unit from the turbocharger, located on the exhaust header/manifold between the engine and the turbo. Regulating boost is done in a similar bypassing method, but is done before the exhaust gas reaches the turbochargers turbine housing. The size of an internal wastegate is proportionate to the size of the turbo, where as an external wastegate, because it's located outside of the turbo, can be made much larger. An internal wastegate becomes too small when the volume of exhaust gasses coming from the motor exceeds the efficiency of that size wastegate. That's when an external wastegate can be utilized, to vent the extra exhaust gasses to stabilize boost pressure.
Just thought it would make a nice addition to those that like to know more in depth about turbo systems.
not ALL external waste gates are on the manifold, i have see na few that are actualy on the turbine housing before the turbine wheel
Boost...it's a hell-of-a drug
alot of guys will take internal wastegated trubos and weld the wastegate shut then modify the exhaust manifold to accept an external gate.
RIP Tim. i miss you, buddy
