American Iron Tech A haven for those who love classic American muscle cars
Learn How to Use a Multimeter!
Old Nov 23, 2023 | 05:27 PM
Default Learn How to Use a Multimeter!
The Engineering Mindset
3.11M subscribers
1,240,498 views Feb 6, 2023
How to use a multimeter. Find out in this tutorial for transistors, resistance, voltage, current, continuity, AC, DC, batteries, frequency, diodes, LED's, capacitors, temperature and much much more
Old Nov 23, 2023 | 05:30 PM
. 🎁 3D Print your ideas here ➡️ https://pcbway.com/g/67TWLc PCB WAY offer expectational value on circuit boards, 3D printing, injection moulding, CNC and sheet metal fabrication. DO CHECK THEM OUT! Get your PDF Multimeter guide here Link 👉 https://swiy.co/Multimeter-PDF-Tutorial 👉 👉👉 Electronics design software I use ➡️ https://www.altium.com/asp/the-engine... ⚡🛠️ TOOLS YOU NEED 🛠️⚡ ******************************* Get this electronics book ➡️ https://amzn.to/41cCJPk Professional Multimeter -➡️ https://amzn.to/3xu2Vaw Good multimeter -➡️ https://amzn.to/3xrbuTd Professional clamp meter ➡️ https://amzn.to/4140FnK Good Clamp meter ➡️ https://amzn.to/3xqt2is
Outlet tester ➡️- https://amzn.to/3kavg2l Energy monitoring plug ➡️ https://amzn.to/3SkfPl7 Battery tester -➡️ https://amzn.to/3S3fHWI Basic electronics ➡️ kit https://amzn.to/3xuLiqS MY FAVOURITE GEAR 🎥 My camera - https://amzn.to/3YCZ7Q9 🎤 My Microphone - https://amzn.to/3YYXsUC ⌨️ My Keyboard - https://amzn.to/3lBsl33 🖥️ My monitor - https://amzn.to/415BGjW 🎧 My headphones - https://amzn.to/3lN7R7u 👋 SOCIALISE WITH US 👋 ******************************* 👉FACEBOOK: / theengineeringmindset 👉TWITTER: / theengmindset 👉INSTAGRAM: / engineeringmindset 👉WEBSITE: Http://TheEngineeringMindset.com 👀 Links - MUST WATCH!! 👀 ******************************* ⚡ELECTRICAL ENGINEERING⚡ 👉How electricity works:
Old Nov 23, 2023 | 05:31 PM
👉Three Phase Electricity:
👉How Inverters work:
👉How TRANSFORMER works:
👉How 3 Phase electricity works:
👉How Induction motor works:
👉What is a KWH:
👉How induction motor works:
❄️ CHILLER ENGINEERING ❄️ 👉Chiller Efficiency improvements:
👉Chilled water schematics:
Old Nov 23, 2023 | 05:32 PM
👉Chiller crash course:
👉Chiller types:
👉Chillers/AHU/RTU:
👉Water cooled chiller Part1:
👉Water cooled chiller Part2:
👉Water cooled chiller advanced:
👉Air cooled chiller:
👉Absorption Chiller :
👉Chiller/Cooling tower/AHU:
👉Chiller flow rate:
👉Chiller fault troubleshooting:
👉Chiller COP calculation:
👉Chiller cooling capacity calcs:
👉Chiller compressors:
👉Chiller expansion valve:
👉Chiller surge:
👉Chiller condenser:
👉Chiller evaporator:
👉Chiller compressor centrifugal:
👉Chiller cooling capacity:
🌡️ HVAC ENGINEERING 🌡️ 👉HVAC Basics:
👉Boilers/AHU/FCU:
👉How Heat Pump works:
👉Heat pumps advanced:
👉Fan Coil Units:
👉VAV Systems:
👉CAV Systems:
👉VRF Units:
👉Cooling load calculations:
👉Pulley belt calculations:
👉Pump calculations:
👉Fan and motor calculations:
👉HVAC Cooling coils:
👉Cooling towers:
⚗️ REFRIGERATION SYSTEMS 🌡️ 👉How refrigerants work:
👉Thermal expansion valves:
👉Refrigeration design software:
Old Nov 23, 2023 | 05:33 PM
👉Design refrigeration system:
👉Reversing valve:
👉How A/C units work:
⚗️ REFRIGERANTS ⚗️ 👉Refrierant retrofit guide:
👉Refrigerant types, future:
🌊 HYDRONICS 🌊 👉Primary & Secondary system:
👉Pumps:
👉Pump calculations:
🔥➡️❄️ HEAT EXCHANGERS 🔥➡️❄️ 👉Plate Heat Exchangers:
👉Micro plate heat exchanger:
🎬 DOCUMENTARY 🎬 👉WW2 Bunker HVAC engineering:
best multimeter for electricians, multimeter review, continuity, fluke multimeter
American Iron Tech
Mar 31, 2018 03:35 AM
bvh
May 13, 2010 06:10 PM
bvh
8
May 13, 2010 06:09 PM
myltwon
Mar 11, 2009 07:54 AM
